Yeah, I like the body styling, altho interior I suspect will be as bland as other Toyotas... Unless someone recolour some trim parts with other colours like silver or woodgrain... depends on which style they want..
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62323
Originally posted by skyzerr33
nope
the orignal version of that engine (mk3 supra and soarer) had the twin turbo's. in later model cars ie the jzx100 they dropped the two small turbos for a single larger one. its more responsive and less laggy aparently.
then, how come all the jzx100s listed at j-spec auction data are twin turbos???
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62661
I think the single turbos were pretty dam rare. The 92 supras had singles and they got vvTi as well. Most of the 1jz's out there are twins dunno why maybe they started concerntrating on the 3.0 2jz and gave up on the old tech.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62685
Even on some supra lots of ppl modify them into a single turbo conversion, as it is far cheaper than buying two sets of turbo and a good single turbo will do the job well.
Alternatively, I think it won't be long until someone stick in a twin turbo charged 2JZGTE engine from a Supra into a Chaser JZX100... Dunno if that can be achieved as gearbox mount, driveshaft length etc could be different. But the engine bay suppose to fit as it looks larger than a Supra.
https://www.sau.com.au/forums/topic/3838-chasers-jzx100/#findComment-62692
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
