  • Replies 92
I'll tell you now boost, ok so after about
A month of searching and searching something
Popped up that just didn't add up, so I saw this guy always down my street with a very tidy SSS pulsar he was a. Regular guy seemed like a real straight shooter until this one day, I had just got home from work when I heard the note of an RB coming down my street so I waited until it had passed me, this 33 gtst was in a primer and looked like it had been at the chop shop, I giggled and walked down to have a chat with him it just seemed to easy and to good to be true about an hour of talking and pretty much covering the whole car it had no vin number no mod plates had been completely stripped, he thought I was just a regular person I gave him the ultimatum and said now this is how it's going to happen Called dad he sent a patrol around and then shit got real, yes he was charged, my dad being as high as he is in the force can pull alot of strings we had the charges dropped on him but at a price, we received the number address and name of the person who sold him the stolen car, and this is where we are today, we have pretty much everything and every person involved in this little syndicate if you wanted to call it that. We are in the final of it all now. 25 people will be charged if all goes well and ACA is on standby for it
Holy shit that's awsomE news and really good luck that you spotted something out of the ordinary .
Hopefully it does come on ACA and they are named and shamed so that import owners can rest easy for once
This news just made my day hopefully all goes well and these scumbags learn there lessons
We aren't worried at all mate about scaring them they won't get far, I can't go into details to much but there on lOckdown :), evidence is there yes but we are matching which person and car are connected and also if we can find owners of the cars they can place there own charges
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
