  • Replies 92
I would suggest everyone go and see Chris.
Soo... Note to self... When I head up to QLD, introduce Chris and Pinky (my car) I am sure she will like him... I am lucky here, at work my car is right outside the door and I can see it from my desk, at home it is in a locked garage in the backyard... When I go out I either park where I can see it or go in someone else's car :) Despite having an alarm, I want an awesome one lol...
Sure! Well I am planning on moving back up early next year hopefully.. Lived up on the Sunny coast (Cooroy) for a few months before ending up back in Canberra *blergh* so looking forward to getting back up there!!!
Soo... Note to self... When I head up to QLD, introduce Chris and Pinky (my car) I am sure she will like him... I am lucky here, at work my car is right outside the door and I can see it from my desk, at home it is in a locked garage in the backyard... When I go out I either park where I can see it or go in someone else's car :) Despite having an alarm, I want an properly installed one lol...
corrected for facts.
the last few cars I have been privy to HAD alarms - I still took the car in 30 sec due to a terrible job.
lochie,
for some reason I am getting people coming to me with info. we should talk at some point and I will bounce them onto you. one tells me slacks ck is a hot spot..
lochie,
Thanks Chris, correction is 100% accurate!
I heard on the grape vine that they are Moari's/samoans and indians. Correct?
Heard that something like 47 imports were recovered in logan village, stripped down to bare shells?
Holy shit,
might be a pretty close co-incidence but I have bumped into a guy who fits the description.
pm me for more details
So dan, you bumped in to a guy that looked like Moari's/samoans and indians.
Good work Sherlok. :teehee:
I doubt theres one word of truth in it, methinx this nighfall character is full of shit.
There are plenty of people in the car comunity with connection to the blue and none has heard a thing. And, skylines are still getting knocked off at an alarming rate.
Unless you can deliver something more concrete than the fairy story you've dropped on us to date op you can suck my large male chicken. :domokun:
Mmm, when I first saw this thread I was stoked, then the gears started turning and it occurred to me that maybe this was just someone trying to lull people into a false sense of security over the holidays. I hope I'm wrong, and this is all legit, but I suggest keeping your guard up during the silly season, regardless.
I was thinking there was always going to be an issue with privacy. His father and uncle should know that he can't go naming names considering its a criminal matter. If in fact it is legit.
Anyway.. If anything it's has made me and others more vigilant.
I roll with my shit off safety.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
