hi guys,
i dont know if this is the right place to ask this so if its not could one of the mods please move
anyway
i have a R32 4door with a SR20 in it (blasphemy i know but thats not the issue) when i bought the car the air con had already been removed,
this isnt too bad on most days but when we are getting high 30 degree days and i can garuntee it will be a hot summer i am seriously thinking of some how getting air con.
now the question can i fit a whole r32 aircon system back into the car?
will the compressor work with the sr20 or will i need a sr20 compressor? if i do need a sr20 compressor will the rest of the r32 system hook up ok?
now the other problem i face is the intercooler is mounted up behind the rad support with the radiator flush mounted behind using up the extra space gained by having the sr20 allowing extra short piping, i then have ducting running up from the front bumper to the intercooler. so the original place for the aircon radiator is no longer available
where could i mount the air con radiator? or is there an option for a smaller aftermarket aircon radiator?
hopefully someone here is a guru on aircon
thanks for your help
https://www.sau.com.au/forums/topic/383928-re-fit-air-con/
you can buy aftermarket a/c condensors mate, you might want to refit the factory condensor and move the the fmic forward a touch, hard to say without seeing any pics.
as for the compressor you will need the sr compressor to fit your sr brackets, then custom lines made on the sr compressor hose fittings then mated with the r32 at the other end. I would go find a good auto sparkie in your area that is into there nissans to take on the job, maybe on gumtree.
I have done such jobs and made custom lines and relocated the reciever drier as they hit the fmic, tho im in brisbane. hope this helps
Edited by mr031
https://www.sau.com.au/forums/topic/383928-re-fit-air-con/#findComment-6125655
that helps heaps, thanks for that.
who sells aftermarket condensor's? is there an option to have a smaller condersor and mount it off to the side similar to how you can mount an oil cooler?
in regards to custom lines, do they have to be hard lines like the fatory ones or is there another option like braided lines?
Edited by Phobic
https://www.sau.com.au/forums/topic/383928-re-fit-air-con/#findComment-6126015
Try a company called Cool Drive for all things air con.
Your condenser will need as much air flow as you can get going over it so a side mount won't work, you will need to re-configure your intercooler setup to make it work properly.
Hard lines connectors will be needed to bolt into the compressor. You can then run with hoses for the rest of the A/C system without the need the need for hard lines, as long as they meet the refrigerant and pressure requirements. Only thing is, is that they are a little more unreliable.
https://www.sau.com.au/forums/topic/383928-re-fit-air-con/#findComment-6126835
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
