hey guys,
Im looking at selling my M-spec R32 ive had it for just under a year. the 1st month after ibrought it the kind fella that sold it to me sold me a dodgie one,so she blew up, But the engine has been replaced with an RB25DE(as i cant drive turbo's)
Shes very clean an i have spent over $5000 on her.
New Rims Koya RG Tecks 18inch 8.5 on the front an 9.5 on the rears + new tyers $2500
the engine an laybor coast $2500
Clutch was replaced with a brand new one at the same time as it had a twin plate in it an it was pretty much stuffed aswell.
just has a excedy sports heavy duity in her now. $600
Has GTR bonnet an Front Grill.
if you have any more questions give me a email.
[email protected]
Im asking $10,000 but will take other offers.
thanks guys :):action-smiley-069::thanks:
http://
heres a few photo's aswell.
p.s its not black. looks it but the paint is flipped out purple ( pretty much the GTR33 colour)
http://i1091.photobucket.com/albums/i388/Savannah_Fahey/skizz.jpg
http://i1091.photobucket.com/albums/i388/Savannah_Fahey/r32.jpg
http://i1091.photobucket.com/albums/i388/Savannah_Fahey/skyline.jpg
https://www.sau.com.au/forums/topic/383945-na-r32-p-plate-friendly/
very interested, can you post up some engine pics?
and are you up for trades/swaps?
will take pics tomorrow night for you an send them your way. whats best email or just post on sau..
what did you have in mind for swaps?? maybe intersted depending on what you have.
sweet, sounds good. if you want just put em up on here, or send to [email protected], whatever is best for you.
currently got an N/A R34 in mint condition, thousands spent and its done only 68,000kms. Rare 25GT-X model.
if your slightly interested i can send some more details.
but if your not, il try to get the cash arranged :).
Edited by R34 0125GT
2 or 4door?. The only reason why I'm selling my'n is because i have a baby on the way. so the 2doors got to go :( as i lover her very much. she's my pride n joey
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
