EOI: Tech Night - 2 - Car Security And Theft Prevention
18th then. it has to be a sat arvo after 1pm.
didnt forget about the dinner. I will be doing the dinner for the club breakup. happy laps I cannot really do without breaking something on the subie.
im keen, but certainly wont be bringin the line.<br>
up to you :)
put it this way the last one was all club members this one at a glance will be at least half and if you are worried about your car being pulled from the crowd , pull me a side afterwards and ask me to quietly look at it.
I had a few people last time that were worried about it (one volunteered a car then withdrew the offer) that simply pulled me a side and asked questions.
the one that withdrew did attend and actually learned a couple of things that session and pulled me aside afterwards.
DATE : 18/12/11
TIME : 1pm
PLACE: 11 GOULD RD Herston
BOOKING IN:
I REQUIRE
your full name
phone numbers (home and mobile)
your MATES phone numbers (if you bring one)
once I have that your name will go on a list.
if you name IS NOT on that list -
YOU ARE NOT INVITED AND WILL BE ASKED TO LEAVE
list is open for bookings now.
how does the arvo of DEC 10 sound. (that's a Saturday for those not paying attention)
joel watling,
you car is one I WANT there. and I think you know why. I would like to talk to you prior to this as I want to discuss a few things with you.
Well i will pretend you didnt just call me Joel then :nyaanyaa:
yeah I goofed!!
it's on the 18th. I was going to close early on the 10th but figured the SATURDAY after would work better.
yeah I goofed!!
Yea, especially if guys have to go home and get their partner for a formal event :no: lol
i would like to go the next one if you have another one as im just waiting on my car back from the work shop, as i paid $1400 for my alarm installed at jb hifi a while ago and know i'm going to regret how dodgy it possibly is
I would like to talk to you. pm me your phone number please.
How long would this go for?
1pm-2pm? Longer?
I would like to attend and let you use my car (34) as an example - as long as 0 harm is done with the screwdrivers...
Will need to confirm with the misses that the date you have set, that we have nothing planned.
I have a mongoose alarm installed by autobarn for $600... would like to see how it goes
rich,
nah no damage. I will probably drop the lower panel off yours though and if I can find what I'm looking for quickly do what I need to and get out of it.
send me a pm with your details once you know whats going on.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
