g35me Posted November 24, 2011 Share Posted November 24, 2011 having trouble with the DW950 injectors, mine dont have a slot cut in the body of the injector where the stock tin retaining clip is meant to slide into like on the stock injectors. is this right? otherwise the only thing holding them in place would be the 5 fuel rail bolts. Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/ Share on other sites More sharing options...
domino_z Posted November 24, 2011 Share Posted November 24, 2011 if you read step 13 of this diy it says most aftermarket injectors dont use the slide clips http://www.speedforsale.com/staff/files/FuelInjectorsGTR.pdf Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6125408 Share on other sites More sharing options...
g35me Posted November 24, 2011 Author Share Posted November 24, 2011 Yes it does Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6125585 Share on other sites More sharing options...
Snowman Posted November 24, 2011 Share Posted November 24, 2011 So - what injectors did you end up with in the car this morning? Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6125644 Share on other sites More sharing options...
g35me Posted November 25, 2011 Author Share Posted November 25, 2011 DW950, it worked. Doing fuel pumps tonight. Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6126222 Share on other sites More sharing options...
Snowman Posted November 25, 2011 Share Posted November 25, 2011 Well then I hope they really are the direct drop in versions At least you don't have kids @ school issues tomorrow should you run into trouble Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6126350 Share on other sites More sharing options...
domino_z Posted November 25, 2011 Share Posted November 25, 2011 ill be there tonight...... watching Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6126416 Share on other sites More sharing options...
g35me Posted November 25, 2011 Author Share Posted November 25, 2011 ill be there tonight...... watching And when that's done we are going to try out Martin's drag tune on E85 Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6126598 Share on other sites More sharing options...
Speedah Posted November 25, 2011 Share Posted November 25, 2011 (edited) having trouble with the DW950 injectors, mine dont have a slot cut in the body of the injector where the stock tin retaining clip is meant to slide into like on the stock injectors. is this right? otherwise the only thing holding them in place would be the 5 fuel rail bolts. I had to machine up a sleeve for each injector so it wouldn't slide up and down (and possibly spitting itself out of the hole in the manifold) Oh...have fun "clicking" the fuel pump assembly back into place inside the fuel tank....did you buy HKS pumps?? Edited November 25, 2011 by Speedah Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6126723 Share on other sites More sharing options...
g35me Posted November 25, 2011 Author Share Posted November 25, 2011 I had to machine up a sleeve for each injector so it wouldn't slide up and down (and possibly spitting itself out of the hole in the manifold) Oh...have fun "clicking" the fuel pump assembly back into place inside the fuel tank....did you buy HKS pumps?? in the end i had no troubles with the DW injectors, pretty easy job really. Changing the fuel pumps was an absolute pain in the ass job that i wouldnt care to repeat again and they were direct fit HKS. Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6127219 Share on other sites More sharing options...
Snowman Posted November 25, 2011 Share Posted November 25, 2011 LOL - I'll definitely let Chris do it then given I also have a roll cage to deal with back there. Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6127259 Share on other sites More sharing options...
domino_z Posted November 25, 2011 Share Posted November 25, 2011 ended up taking two brilliant minds to get that fuel basket opened my head's still spinning from the fumes....... and i was just watching B working away in the back seat Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6127360 Share on other sites More sharing options...
g35me Posted November 26, 2011 Author Share Posted November 26, 2011 ended up taking two brilliant minds to get that fuel basket opened my head's still spinning from the fumes....... and i was just watching B working away in the back seat yeah man thanks for your backyard handyman techniques couldnt have done it without you. Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6127557 Share on other sites More sharing options...
domino_z Posted November 26, 2011 Share Posted November 26, 2011 (edited) go n put te kett'l on Edited November 26, 2011 by domino_z Link to comment https://www.sau.com.au/forums/topic/383976-real-time-help-needed-dw950-injectors/#findComment-6127897 Share on other sites More sharing options...
