Hi all,
Just Jap Racing Sydney, the Australian Distributor for Blitz Japan, is proud to bring our loyal customers some cutting edge specials on the latest range of High Performance Blitz Damper ZZ-R Coilover Suspension Kits, just in time for Christmas!
BLITZ DAMPER ZZ-R STANDARD FEATURES
- 32 Stage Damping Force & Height Adjustable
- Enlarged Piston Design
- Superior Lightweight Design For Reduced Unsprung Weight
- Specially Designed Shock Absorber Valving
- High Strength Cylinder Casing
- Lightweight Forged Alloy Upper Mounts
- High Strength Forged Alloy Spring Locking Seats
- Durable High-Tensile SAE9245 Coil Springs
- Lightweight Alloy Mounting Brackets
- Durable Rubber Dust Boots
- Corrosion Resistant Black Special Anodized Coating
- Blitz Height Adjustment C-Spanners Included
- Fully Rebuildable
- Suitable For Street & Track Applications Via Wide Adjustment Range
AVAILABLE NOW FOR THE FOLLOWING VEHICLES
- Nissan S13
- Nissan S14
- Nissan S15
- Nissan Skyline ECR33
- Nissan Skyline ER34
- Nissan Skyline R32 GTR
- Nissan Skyline R33/R34 GTR
- Nissan 350Z Z33
- Nissan 370Z Z34
- Mazda RX7 FD3S
- Mitusbishi Colt Ralliart
- Mitsubishi Lancer EVO CT9A
- Toyota JZX90/JZX100
PURCHASE NOW FOR ONLY $1399.00 (NORMALLY $1499.00) + FREE DELIVERY!
HOW CAN YOU PLACE YOUR ORDER?
The answer is simple!
Purchase these and many other fantastic Blitz products online now via our massive website at http://www.justjap.com for fast Australia-wide delivery.
With Australia's biggest range of High Performance Japanese Parts all under one roof, and all available online, purchasing your tuning parts online couldn't be easier!
Please contact our sales team if you have any questions, or reply here
Blitz shocks used to be by Sachs. Do you know if this is still the case?
Hi Roy,
I don't believe so but will verify
Steve
any chance you have these to suit 34gtr?
Absolutely :) We have 3 sets for BNR34 on their way from Japan, currently due in January.
If you would like to secure one of these sets before they arrive, please give Darron a quick call on (02) 9545 0532 and he will be more than happy to look after you.
Cheers,
Steve
  • 1 month later...
Keep the orders coming - We will not be beaten on price!
Buy with confidence from the Australian Blitz Distributor, Just Jap Racing :)
The quality of these Coilovers is amazing have a set fitted to my evo 7 and a set in my cousins Evo 8 the ride is great and the adjustment you can do is huge ! I would recommend these over bc
Cheers for the reply, might buy a set when I get paid. Looked at the BCs and Blitz side by side, thought the blitz might be the go.
yep side by side the blitz quality is amazing im not saying the bc arnt good but my personal opinion is that blitz ones are worth the little extra
Heaps more stock now available.
New kits have just arrived for BNR32, BCNR33/BNR34, 350Z, 370Z and FD RX7
Get your orders in now for fast AND free Australia-wide Delivery!!
  • 4 months later...
Hi David, apologies for not responding earlier, I have just seen this post now.
These do not come from BC, we source these directly from Blitz Japan.
There are a number of coilovers on the Market that do share a number of similarities, ie Trust and Blitz - What you can be assured of with Blitz is a superior quality product from one of the biggest and most reputable Japanese tuning companies.
Which brand you select ultimate depends on your purpose, though its worth noting we have only had outstanding feedback and response from customers on the Blitz ZZR's since we began selling them.
Regards,
Steve
Are they made by blitz or out sourced though ?
They are a Blitz genuine product.
Please check their website for further details:
http://www.blitz.co.jp/products/suspension/damper_zz-r.html
Cheers,
Steve
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
