Epic failure on the tapping
Driller the hole no issue seamed to tap it no issue
When trying to screw the sensor in broke the end off the sensor because is started going in at the wrong angle
Look like the hole is not big enough by a tiny amount
What sized tap do i need, i was provided with the following item:
1/4
19
BSPF
Taper
11.8
Drill(mm)
HSS
Ground Thread
Part No:3046-1/4T
Yay another week and no car
https://www.sau.com.au/forums/topic/384053-welding-needed/#findComment-6127824
Tis is the sensor
http://adaptronic.com.au/products.html?page=shop.product_details&flypage=flypage_new.tpl&product_id=52&category_id=5
M14x1.5
By this chart,
http://www.coasteltools.com/tech_tap_drill_mf.htm
im guessing i need a 12.5mm Tapwhere as the one i was sold is a 11.8?
One is was sold http://www.bordo.com.au/_productDetail.php?productId=4906
Should have looked the info up before i went to the shop, but the shop visit was an unscheduled, look a tool shop lets go in type of visit.
If this info is correct i have plenty of room to drill out alittle further
Can some one who knows this stuff confirm if i am correct?
https://www.sau.com.au/forums/topic/384053-welding-needed/#findComment-6127898
