Just clearing out some stuff that is no longer needed.. I am open to offers.
All parts located in Penrith, Western Sydney.. Will post but note clutch is heavy and will cost approx $50 to post
R34 GTT brake master cylinder + booster.. Bought it because I thought my booster was farked but all was well so just onselling it.. $120+postage
Q45 AFM (90MM) I bought this with the intention of using on my car but looking at going MAF-less ECU so its no longer needed.
As you can see in the pics the mesh is pefect and the body has no cracks or scratches. Comes with a used plug $100+ Postage
R33 Gts-t/R34 N/A heavy Duty Clutch + OEM Flywheel.. Started slipping at high RPM and was replaced with a Hyper Single
Clutch disc needs replacing ($150 from kudos motorsports+shipping) all surfaces are still perfectly flat and smooth. Includes flywheel and pressure plate.. Looking for $100
send me a txt on 0412589924 or pm me here.
Thanks,
David
bump.. booster $100
Clutch $20
also have my old r34 GTT Impul Front bar that was used as a drift bar, its fiberglass.. has some small cracks and will need a repair/spray if you want to use it everyday.
has been cut to fit FMIC $50
ask and ye shall recieve..
mainly scraped on the bottom of the bar from hitting on a driveway.. minor cracks/chips on the face but would be fixed if you decided to repaint it
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
