Lately ive been having this weird problem where sometimes my indicators will make a fast ticking sound like one of my globes are blown after ive just used the indicator and the only way to stop it is to push the indicator stick up a little bit.
When its ticking really fast the indicators aren't actually working. Seems to be happening allot more frequently aswell.
Also none of the globes are blown because the indicators work perfectly fine.... its just randomly after turning a corner it will make the fast ticking sound.
Anyone had this problem and know how to fix it?
https://www.sau.com.au/forums/topic/384072-weird-indicator-problem/
  • 1 month later...
bump... it has just gotten worse. today it wont turn off the fast ticking unless im indicating then its normal. But when im not indicating its doing the fast ticking noise.... also i noticed a bit of smoke come out of there so i shut my car down really quickly.
any ideas?
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
