Hey guys,
So since i bought my 34, iv noticed that my headlights are angled too high, and when driving behind someone that is about 10 metres in front of me, it looks like i am blinding them! (and i dont even have HID's yet!)
iv tried playing around with the adjuster near the drivers side, but im pretty sure thats broken.
Iv heard that is a screw near the headlight itself where it can be adjusted, but i cant seem to find it
can anyone help me out with this, and if possible, post up some pictures
thanks!
https://www.sau.com.au/forums/topic/384093-r34-gtt-headlight-issues/
Have a look in the DIY section, some guy has a tutorial on installing HID's to his R34 headlights, on one of the pic, it shows the little adjustment screw.
i had a look in the DIY, and dont think i found it.
can someone link me to it, or please try help somehow!
  • 1 month later...
did you even try i serched R34 HID and come up with this mate
http://www.skylinesaustralia.com/forums/topic/269525-r34-gtr-xenon-hid-install/page__p__5483102__hl__r34+hid__fromsearch__1#entry5483102
That's the one lol, didn't think it was too hard to find...
Most cars have an adjuster. looks like a little cog that you can lever slowly with a flat blade screw driver. I did a 370z on the weekend only I adjusted them up not down. Park 1 meter away from a white wall, put the lights on and adjust. 10mm of adjustment of the beam on the wall will give you about 5-10m on the ground (most cars vary)
white cog if you look at the bonnet catch look left or right and you will see it just behind the light it may have a screw type bolt going to it for easy adjustment or it wont if not go upto a wall close and turn it you will see wat it does then go back like old mate said befor and adjust it right for you
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
