did a bit over the weekend
diff needs redoing so thought may aswell pull the rear end out while im at it and try to get some less camber out of it
stripped it all down
brae (bag26n) was kind enough to make us up some solid subframe bushs raising the subframe 30mm, thanks mate
also started on making up a bash bar, just playing with ideas at the moment
FYI : when i went to 4 bolt driveshafts i used hr31 companion flanges, i was told by numerous sources that thats what you use, when i fitted the companion flange it would sit about 10mm outside of the a arms, it didnt seem right but i just assumed thats how it has to be, only by chance i discovered they where wrong! brae had is hr31 apart and had done z31 5 stud conversion, i borrowed a z31 companion flange just to compare out of curiosity and boom!....
z31 companion flanges are shorter so anyone wanting to put hr driveshafts in r30 u must run z31 flanges!
got a w/a yesterday.
cars now running -1 deg rear camber and 1mm total toe in, opposed to -3 deg. camber and up to 6mm total toe in.
stoked with the results, car has heaps more grip, x member mod has worked out well. keen to see how it skids
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
