^ haha will post something up soon dude,
so bit the bullet and upgraded my coilovers, first time ive ever had brand new coil overs, should be good
ended up getting CS2s with 9kg fronts 7kg rear. pretty easy fit, just needed to redrill the rear strut tower to two bolt. cheers to brae for his wisdom and help!
fronts had been leaking for ages and where only tein HAs
^ one of the main reasons i go these was because of the extra castor adjustment u can get, still need more thou so will look into modifying these in the future
  • 1 month later...
^ haha no worries, yea i miss the fj :( i have ideas of going back to one, you never know.....
Brae was nice enough to mod my LCAs 25mm, so 50mm total more track, should be good, fitting up new balljoints and bushs today
thanks mate
also did the hit and run waki day couple weeks ago, second time at waki, pretty cool lil track
this is what ive been playing around with recently, basically wanted to get rid of the castor bushs and go a rose joint, theres a few kits ive seen but i still think they have to much going on, wanted to keep it simple, so to follow the trend of silvia front end, ive gone to modified s14 castor arms, boxed and modded dr30 castor brakets to suit
boxed and brace welded in
brae worked his majic and extended these by 75mm, will look into making up a one peice section next year when im sure the lenghts are spot on
dummy fit in car
hole saw out original castor bush mounts re drill to suit rose joint,
i wanted the rose joint to bolt up here as its the strongest part of the castor braket
boxed up
also got these offset rack mounts, hopefully theyl work...
love this build, its DR30 and drift what more could you want
now with the new castor rod set up you'll be setting up the camber tops to be camber adjustable only i figure
also give us an update on how the powered by max offset rack mount bushes go and if it reduces bind for the 6mm of location change
  • 3 weeks later...
figured out the lenghts needed, Brae worked his majic again, and made up a one piece section, since we used GKtech castor arms and then modified them, we thought it would be good to appropiately name them "GF Tech" ;)
cheers again brae for all your help!
fitted up a s14 rack, you can kind off make out the difference in thickness, on the left hand side tube, fitted up pretty easy, just needed to use the s14 low pressure fitting, and bend high pressure fitting abit to suit, im hoping because the s14 rack doesnt have the speed sensor in it, maybe my steering will be better...
ive also fitted up the psm rack mounts, so far so good
also needed these, with the extended lcas, tie rods ran out off thread ... these are said to give u 25mm extra tie rod length and 19mm more rack travel..
drifting next weekend, hopefully car goes well
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
