  • 4 weeks later...
so trying to motivate has been hard, but im slowly getting there, been gathering a few bits...
fuel system is like 10 years old, so thought better be safe and upgrade, gone carter black and 044.
so to help with motivation i finally got my flare back!
i bought a blitz water temp gauge when in japan, brae made it hectic,
more motivation, 35r
and even more motivation!
im aiming for three weeks be running again, still need to fix diff and the rack and some other things i forgot, hopefully soon,
yea, so im sick of paying the diff place to re do the diff, and since they wouldnt help me out with price even after ive been there more than 10 times with the thing (end rant) i did a small bit of research, spoke to tim wilkins and he was more than happy to help me out, so im doing it myself!! ahh feel better now!!
shits apart
so when i pulled it apart found there attempt at making a shim!
all 4 of the phillips heads that held the hemi where all munted so changing them to allen key cap screws
yea so there piece of tin was .3mm
spoke to brae and we figured out .6mm should be the go! thanks again !
so from what i found if u use a .5mm shim your preload would be around 75/80fpds, i want 95/100 so hopefully itl obviuosly lock hard but as it wears will take longer to start opening up.
im still not finishined so this is in experiment mode, tim reckons i wont need them, but ill wait and see when i get the new plates from him,
also to help me with my memory /others out later
(( 1|1|1 centre 1|1|1))
yea so 14 plates total.
doing it your self = knowing exactly whats been done to it :)
i'm not too sure how these diff's work although be sure to take the back lash into account, so once you shim it up test the backlash and see if it needs adjusting.
after shimming my r200 into a locker the backlash is crap and low rpms are annoying, i just cant be stuffed changing the backlash shims just yet lol
thats it! and if i f**k it up i only have myself to blame! hahah but yea backlash should be fine since i only pulled out centre??
Nice choice of fuel system, same as mine. I made a under car surge tank to keep it all nice and neat.
haha steve ! looks like im heading the right way! man ive dummy fitted the carter pump, sux that it has to be mounted upright, kinda limits positions
yea ok so im no diff expert, but after talking to someone who is, i found out that these type of lsds shouldnt be shimmed! it basicallly just makes it a locker and completley stuffs up how the lsd plates work/lock up.
so the only way to get preload is to add another spring plate so, it will have 6 spring plates instaed of four.
((( |1|1 centre 1|1|)))
ive done mine like this with the best springs i had, so trail and error at moment, basically i should have just got a kaaz years ago
so when i was torqueing up the crown bolts, i snapped one, im blamming the amount of use they have had, so upgraded to 11.1 allen key. much better than stock, and look pretty.
also when trying to find main cap specs, this came up on search engine, haha
so true!
i ment short nose r200 r33 diff, the back lash shims are just behind the crown wheel and you unbolt the center into two bits and install the shims with in, so safe bet is its completely different diff from what your describing
  • 4 weeks later...
so car runs finally! getting somewhere now!
forked out for a 6 boost, awesome mani but massive burn, cheers to brae for the screamer work! also went 50mm gate
fuel system done!
gav at garage 48 welded up turbo elbow and dump pipe
cool stuff
and yea complete! well kinda, still need to do a catch can and some other stuff but getting there!
cars currently at mrc for tuning, hanging to drive a again!
  • 4 weeks later...
so yea finally got to skid again ! and man it was good! as u could probally see from previous posts id been real bummed just been pouring money in and not getting any return. cars and animal ! loving it again!
yea so I managed to rip my oil cooler off unloading it off the trailer, was awesome. but yea I upgraded to a much larger and better toyo core
I mounted it in between rad a cooler to make sure it doesn't again
limo is awesome Im just looking for a 3.9 ratio now cars just alittle to boggy and I don't have the skills to go fast enough
I also getting heaps of bind o and the rack popped again, so im getting rid of offset spacers and moving rack forward
I thought I had more pics but I don't know where
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
