  • 4 weeks later...
so trying to motivate has been hard, but im slowly getting there, been gathering a few bits...
fuel system is like 10 years old, so thought better be safe and upgrade, gone carter black and 044.
so to help with motivation i finally got my flare back!
i bought a blitz water temp gauge when in japan, brae made it hectic,
more motivation, 35r
and even more motivation!
im aiming for three weeks be running again, still need to fix diff and the rack and some other things i forgot, hopefully soon,
yea, so im sick of paying the diff place to re do the diff, and since they wouldnt help me out with price even after ive been there more than 10 times with the thing (end rant) i did a small bit of research, spoke to tim wilkins and he was more than happy to help me out, so im doing it myself!! ahh feel better now!!
shits apart
so when i pulled it apart found there attempt at making a shim!
all 4 of the phillips heads that held the hemi where all munted so changing them to allen key cap screws
yea so there piece of tin was .3mm
spoke to brae and we figured out .6mm should be the go! thanks again !
so from what i found if u use a .5mm shim your preload would be around 75/80fpds, i want 95/100 so hopefully itl obviuosly lock hard but as it wears will take longer to start opening up.
im still not finishined so this is in experiment mode, tim reckons i wont need them, but ill wait and see when i get the new plates from him,
also to help me with my memory /others out later
(( 1|1|1 centre 1|1|1))
yea so 14 plates total.
doing it your self = knowing exactly whats been done to it :)
i'm not too sure how these diff's work although be sure to take the back lash into account, so once you shim it up test the backlash and see if it needs adjusting.
after shimming my r200 into a locker the backlash is crap and low rpms are annoying, i just cant be stuffed changing the backlash shims just yet lol
thats it! and if i f**k it up i only have myself to blame! hahah but yea backlash should be fine since i only pulled out centre??
Nice choice of fuel system, same as mine. I made a under car surge tank to keep it all nice and neat.
haha steve ! looks like im heading the right way! man ive dummy fitted the carter pump, sux that it has to be mounted upright, kinda limits positions
yea ok so im no diff expert, but after talking to someone who is, i found out that these type of lsds shouldnt be shimmed! it basicallly just makes it a locker and completley stuffs up how the lsd plates work/lock up.
so the only way to get preload is to add another spring plate so, it will have 6 spring plates instaed of four.
((( |1|1 centre 1|1|)))
ive done mine like this with the best springs i had, so trail and error at moment, basically i should have just got a kaaz years ago
so when i was torqueing up the crown bolts, i snapped one, im blamming the amount of use they have had, so upgraded to 11.1 allen key. much better than stock, and look pretty.
also when trying to find main cap specs, this came up on search engine, haha
so true!
i ment short nose r200 r33 diff, the back lash shims are just behind the crown wheel and you unbolt the center into two bits and install the shims with in, so safe bet is its completely different diff from what your describing
  • 4 weeks later...
so car runs finally! getting somewhere now!
forked out for a 6 boost, awesome mani but massive burn, cheers to brae for the screamer work! also went 50mm gate
fuel system done!
gav at garage 48 welded up turbo elbow and dump pipe
cool stuff
and yea complete! well kinda, still need to do a catch can and some other stuff but getting there!
cars currently at mrc for tuning, hanging to drive a again!
  • 4 weeks later...
so yea finally got to skid again ! and man it was good! as u could probally see from previous posts id been real bummed just been pouring money in and not getting any return. cars and animal ! loving it again!
yea so I managed to rip my oil cooler off unloading it off the trailer, was awesome. but yea I upgraded to a much larger and better toyo core
I mounted it in between rad a cooler to make sure it doesn't again
limo is awesome Im just looking for a 3.9 ratio now cars just alittle to boggy and I don't have the skills to go fast enough
I also getting heaps of bind o and the rack popped again, so im getting rid of offset spacers and moving rack forward
I thought I had more pics but I don't know where
    • Front wheeled vtec powered rb monster
    • Looking forward to the build thread!
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
