^ haha will post something up soon dude,
so bit the bullet and upgraded my coilovers, first time ive ever had brand new coil overs, should be good
ended up getting CS2s with 9kg fronts 7kg rear. pretty easy fit, just needed to redrill the rear strut tower to two bolt. cheers to brae for his wisdom and help!
fronts had been leaking for ages and where only tein HAs
^ one of the main reasons i go these was because of the extra castor adjustment u can get, still need more thou so will look into modifying these in the future
  • 1 month later...
^ haha no worries, yea i miss the fj :( i have ideas of going back to one, you never know.....
Brae was nice enough to mod my LCAs 25mm, so 50mm total more track, should be good, fitting up new balljoints and bushs today
thanks mate
also did the hit and run waki day couple weeks ago, second time at waki, pretty cool lil track
this is what ive been playing around with recently, basically wanted to get rid of the castor bushs and go a rose joint, theres a few kits ive seen but i still think they have to much going on, wanted to keep it simple, so to follow the trend of silvia front end, ive gone to modified s14 castor arms, boxed and modded dr30 castor brakets to suit
boxed and brace welded in
brae worked his majic and extended these by 75mm, will look into making up a one peice section next year when im sure the lenghts are spot on
dummy fit in car
hole saw out original castor bush mounts re drill to suit rose joint,
i wanted the rose joint to bolt up here as its the strongest part of the castor braket
boxed up
also got these offset rack mounts, hopefully theyl work...
love this build, its DR30 and drift what more could you want
now with the new castor rod set up you'll be setting up the camber tops to be camber adjustable only i figure
also give us an update on how the powered by max offset rack mount bushes go and if it reduces bind for the 6mm of location change
  • 3 weeks later...
figured out the lenghts needed, Brae worked his majic again, and made up a one piece section, since we used GKtech castor arms and then modified them, we thought it would be good to appropiately name them "GF Tech" ;)
cheers again brae for all your help!
fitted up a s14 rack, you can kind off make out the difference in thickness, on the left hand side tube, fitted up pretty easy, just needed to use the s14 low pressure fitting, and bend high pressure fitting abit to suit, im hoping because the s14 rack doesnt have the speed sensor in it, maybe my steering will be better...
ive also fitted up the psm rack mounts, so far so good
also needed these, with the extended lcas, tie rods ran out off thread ... these are said to give u 25mm extra tie rod length and 19mm more rack travel..
drifting next weekend, hopefully car goes well
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
