couple of pics from the adgp straya day drift festival,
i had a major set back when i went for a alignment on the friday, which saw me brae and gav working on the car till 3 am the morning of the event, if it wasnt for those two guys i wouldnt of made it. thanks guys !
ill go into that later, heres a couple of pics from the day,
ok so heres was my set back...
From putting my car on the trailer to the wheel aligners the alloy piece of the castor arm had started to bend, basically to dangerous to risk driving the car on. we put this in the vice to check strength and literaly pushed on it by hand and "snap"
dont get me wrong im not bagging GKtech. im a big fan of there stuff, i shouldnt have modified there gear and played around w alloy suspension pieces to start with. just a little upsetting.
i was soo lucky that juzzo had a old set off s14 castor arms (metal) and Gav from garage 48 was nice enough to work his magic into the early morning along w brae, coming up w these lenghtnd and much stronger version of castor arms, did a rough allignment, got 3 hours sleep and went drifting ... once again massive thanks to these dudes, without them i would have been nowhere
also my flares didnt last to long... took out a tyre stack :(
had so much fun on saturday, i couldnt be happier! there are some more drifting photos ill put up shortly
  • 4 weeks later...
not much of an update, but finally forked out for a trailer. big burn but had to be done. car jut fits!
also got these, the other spacers where amazing but i got allot of bind and wheel shake, so hopefully these sort it out for now, if they work i will be moving rack forward and using the garage 7 spacers again.
drifting tomorrow hopefully all goes well
massive drift hangover,
clutch is starting to slip in 4th, limo needs to be re- done, and rack has popped its seals..
cars being parked for awhile. along while ...
on the plus side i had fun and wheel shake has gone but im still getting bind...
anyway here a couple of pics from yesterday,
i miss my flare :(
  • 2 months later...
soo been trying to motivate myself since last outing, havent really touched it, sold turbo setup,
awsome
got motivated to pull the covers off and paint them properly hopefully when they done ill be even more motivated to fix all the problem,s with it,
1zb7y8m.jpg this took me hours to get to this, was really fun,
found some motivation, getting shit done...
im still not sold on color,maybe im just not used to it looking all shiny anyway now i need to paint some more pieces and go braided rocker covers to make it all work...
also it made sense yo fit up mines baffles while it was all off
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
