  • 4 weeks later...
so trying to motivate has been hard, but im slowly getting there, been gathering a few bits...
fuel system is like 10 years old, so thought better be safe and upgrade, gone carter black and 044.
so to help with motivation i finally got my flare back!
i bought a blitz water temp gauge when in japan, brae made it hectic,
more motivation, 35r
and even more motivation!
im aiming for three weeks be running again, still need to fix diff and the rack and some other things i forgot, hopefully soon,
yea, so im sick of paying the diff place to re do the diff, and since they wouldnt help me out with price even after ive been there more than 10 times with the thing (end rant) i did a small bit of research, spoke to tim wilkins and he was more than happy to help me out, so im doing it myself!! ahh feel better now!!
shits apart
so when i pulled it apart found there attempt at making a shim!
all 4 of the phillips heads that held the hemi where all munted so changing them to allen key cap screws
yea so there piece of tin was .3mm
spoke to brae and we figured out .6mm should be the go! thanks again !
so from what i found if u use a .5mm shim your preload would be around 75/80fpds, i want 95/100 so hopefully itl obviuosly lock hard but as it wears will take longer to start opening up.
im still not finishined so this is in experiment mode, tim reckons i wont need them, but ill wait and see when i get the new plates from him,
also to help me with my memory /others out later
(( 1|1|1 centre 1|1|1))
yea so 14 plates total.
doing it your self = knowing exactly whats been done to it :)
i'm not too sure how these diff's work although be sure to take the back lash into account, so once you shim it up test the backlash and see if it needs adjusting.
after shimming my r200 into a locker the backlash is crap and low rpms are annoying, i just cant be stuffed changing the backlash shims just yet lol
thats it! and if i f**k it up i only have myself to blame! hahah but yea backlash should be fine since i only pulled out centre??
Nice choice of fuel system, same as mine. I made a under car surge tank to keep it all nice and neat.
haha steve ! looks like im heading the right way! man ive dummy fitted the carter pump, sux that it has to be mounted upright, kinda limits positions
yea ok so im no diff expert, but after talking to someone who is, i found out that these type of lsds shouldnt be shimmed! it basicallly just makes it a locker and completley stuffs up how the lsd plates work/lock up.
so the only way to get preload is to add another spring plate so, it will have 6 spring plates instaed of four.
((( |1|1 centre 1|1|)))
ive done mine like this with the best springs i had, so trail and error at moment, basically i should have just got a kaaz years ago
so when i was torqueing up the crown bolts, i snapped one, im blamming the amount of use they have had, so upgraded to 11.1 allen key. much better than stock, and look pretty.
also when trying to find main cap specs, this came up on search engine, haha
so true!
i ment short nose r200 r33 diff, the back lash shims are just behind the crown wheel and you unbolt the center into two bits and install the shims with in, so safe bet is its completely different diff from what your describing
  • 4 weeks later...
so car runs finally! getting somewhere now!
forked out for a 6 boost, awesome mani but massive burn, cheers to brae for the screamer work! also went 50mm gate
fuel system done!
gav at garage 48 welded up turbo elbow and dump pipe
cool stuff
and yea complete! well kinda, still need to do a catch can and some other stuff but getting there!
cars currently at mrc for tuning, hanging to drive a again!
  • 4 weeks later...
so yea finally got to skid again ! and man it was good! as u could probally see from previous posts id been real bummed just been pouring money in and not getting any return. cars and animal ! loving it again!
yea so I managed to rip my oil cooler off unloading it off the trailer, was awesome. but yea I upgraded to a much larger and better toyo core
I mounted it in between rad a cooler to make sure it doesn't again
limo is awesome Im just looking for a 3.9 ratio now cars just alittle to boggy and I don't have the skills to go fast enough
I also getting heaps of bind o and the rack popped again, so im getting rid of offset spacers and moving rack forward
I thought I had more pics but I don't know where
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
