  • 1 month later...
so to carry on with me having no idea what im doing, this happened
fair spin out for myself been over 10 years since ive seen a fj20 in the bay! and man does it look good!
just by chance i came across this low k s12 engine, and just thought f**k it so bought the fj sold the rb26/30 sold turbo setup and all the other shit and focusing on buying fj parts
so ive got a
gtx 30/76 .82
1000cc rochesters w ashford rail
2x40mm gates
going to run a external crank trigger and eventually external oil pump setup, just going to get it all going first then take it as it comes, car will be on some sort of e85 hoping for a 300kw + setup
also billy was super nice and modded a r32 crossmember for me moving it forward 25mm, so i can piss off the offset spacers, i need to get a longer steering shaft of spacer made up to work, should be done soon,
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
