you are working it out at the flywheel not the rear wheels, it is also working out using gasoline stoich of 14.7:1, which you will know isnt going to work at WOT on a turbo car without detonating its ring hole out
Also, Naturally aspirated and turbo engines are completely different
So Stop miss leading people
OK
I picked up from this forum for you.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results
Posted 16 June 2011 - 03:58 PM
Just had my car re-tuned at EFI performance today after putting heavy duty actuator on:
Power FC
Apexi AX53B70 p25 turbo
Stock air box
Walbro fuel pump
Tomei adjustable fuel reg
Vulture motorsports plenum
Front mount IC
Apexi 3.5 inch exhaust
Stock injectors
Stock air flow meter
250kw
Posted 21 June 2010 - 07:43 PM
dynapack hub dyno. full boost by 3500rpm.
256rwkw @ 13.8psi
98 octane.
kkr430 / dsr430 internal wastegate
fuel pressure reg upped pressure on standard injectors
intercooler
external walbro pump
Posted 08 January 2010 - 09:48 PM
1998 R34 GTT
unopened RB25DET Neo, 80,000kms
shell Optimax 98 Fuel
stock injectors
stock fuel pump
nizmo Fuel Pressure Reg
powerFC
greddy boost controller
hks FMIC
hkd pod
z32 afm
Garrett GT3071R
3.5" turbo back exhaust
261KW@wheels @15psi
Could you believe me or do you want to more?
You can pick many cars from forum.
Also I tuned hiflow turbo and stock injector car over 30 cars.
  • Replies 63
ermmmm, every one of those examples had an adjustable fuel pressure regulator...
I thought this was all about standard injectors with standard rail pressure?
you could probably make 1000hp out of 370cc injectors if you run 300psi rail pressure...
Also Kasko, go the NIStune, easy to use software and does everything thing you need. and if ya need to change something you can just get a retune done locally and your set.
I've got mine running from my sterio (carpc), so i can fill up with e85 and change the tune while sitting at the servo.
This...Also got a PM from him saying the same crap
all were either hub dynos (read higher than DD rollers) and/or had an adjustable reg
most of them didnt even have turbos capable of making 250+
Also said that to do it, you MUST still have the standard rubber turbo inlet....errr...righto
What exactly are we talking I need for Nistune though.
I been trying to read up about it and it sounds like a bit of a screw around.
Tell me if im missing anything.
Also do I lose any functions such as my aircon etc.
-Z32 ECU or R32 ECU (what motor from the R32?)
-Z32 AFM
-Some window switch (read about it but wouldnt have a clue why I need it lol)
-Nistune board (do I need software or is that only if i want to have it on my own laptop?)
Thanks guys
Ahk, you can either use a Z32 ECU and find someone to install who has done them before (need to swap a few pins around on the ECU plug)
or and R32 RB20 (gtst) Ecu, easiest option as it plugs straight in, but Rb20s do not have the variable cam timing, which is where the MSD window switch comes in (you use it to switch vct on and off, on at ~1100rpm and off at 4700rpm)
You dont need the software unless, as you say you want the software on a laptop, It is handy if you want to run E85 and PULP as you need to change the maps
No functions lost, will retain A/C, power steer idle up etc etc
so it is all as per factory (it is a factory ecu after all ;) )
Haha I was worried I was going to forget to switch it and end up looking like this.
So now.
My plan is to price those things.
Then work out between Nistune and a toshi
I would love to get a Nistune but trying to find everything
and get good prices seems to be a stress.
Thanks guys for the input. :)
Also even if he is wrong with that shit.
His saying $700 for an ECU + road tune with him. (1 hour)
Seems pretty reasonable?
I told $700 road tune and dyno tune include 1 hour dyno tune.
For std turbo Road tune only $550 dyno tune only $600 include R33 ecu modified and chip.
Road tune and dyno tune start 10AM finish around 4-5 PM
I real time tuned Mr David Stankowski RB25det engine drift car in gold cost last time QLD trip and he got second place after my tune! PRO TOUR 2011-----Round 4----QLD RACEWAY----Sun july 31
http://www.nissansilvia.com/forums/index.php?app=core&module=search&do=search&fromMainBar=1
He is using my remapped ecu.
Not nistune board.
I'm over this...
If you want to keep telling people they will make a GENUINE 250rwkws on standard injectors with a standard pressure reg, then go for it
One last thing though, how many of those 250rwkw (with a standard pressure reg) cars have backed it up on the strip by running 110+mph
I bet none of them have
Edit - it would be more like 115-120mph
as I was running 107 with 200rwkws
How is this
My customer 300zx ,std 370cc same size RB25det injector ,std fuel pump, std AFM, std turbo , std fuel regulator,stock dumps and front pipes.
250rwkw at 15 psi 11.5 fuel ratio on mainline dyno.
http://aus300zx.com/forum/showthread.php?t=314288&highlight=toshi
you are really fishing for results now aren't you
LOL at the lean spot at peak torque...have to pull much timing there to stop it pinging its head off?
and peak power at 4000rpm? nah I dont think so.
try again
try again
Im using knock monitor k-mon and knock around 20.
Anyway Im talking about injector.
This injector is 370 cc and std fuel regulator.
220kw is not injector max.
OK
What % is your injector duty?
Normally under 80% is best.
Around 230-240kw 80%.
250kw is around 85% but if car is not race car I think injector do not over heat.
If your tuner think injector duty 70-75% is safe for race car , yes,Im agree.
But its not injector max.
My car saw 100% at 235kws and started to lean out (had a big fuel pump too)
The injector needles do not close properly over ~90% duty and the spray pattern and fueling goes to shit as the solenoid in the injector cannot keep up
which ever dyno you are using is reading high if you think that 240rwks is possible at 80%, you are only getting around 300cc/min which on a 2.5L 6 cylinder engine is worth around 300BHP which is 225kws at the flywheel! factor in a 16-17% drive train loss you are looking at roughly 190rwkws
which coincidentally my Rb25 made 195rwkws at 13psi and 82-84% max duty cycle
Go the PFC or any other stand alone
R33 Ecus really do not like the Emanage (from experience) the standard ECU has too many protection features.
Here are some NEW options available to you
http://adaptronic.co...7&category_id=1
http://wolfems.cart....ils/696060.html
http://www.vi-pec.co...s/pluginecu.htm
But for ease of use (ala plug it in and drive the pfc is great)
but note, despite the Wolf, Vi-Pec and the Adaptronic being more expensive, you wont have to buy a Z32 AFM when you want more power as they are map based ECUs
They also all have inbuilt boost control, just need to buy a solenoid and wire it up. they can also control extra fuel pumps, thermo fans, Nitrous, support data logging, trac control multiple temp based rev limits pretty much anything you want.
The PFC will not run any extra things, so if you want any of the above you have to either get additional controllers etc
the Wolf and the Adpatronic can run flex fuel sensors if you want to go E85 or PULP or anything in between.
ESP are Vi-Pec dealers, and they go for around 1600-1700 + tune
Something to think about
the vipec will also run the flex fuel sensors.
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
