Oh and how many times does a guy have to fork out 100 bucks for dyno time for each chip. Not to mention not bring able to drive the car.
Simply guessing the tune is a horrid way to do things
So it is 500 bucks for the chip + 100 dollars or more for a dyno check, tune is crap, send ecu back fit new chip, another 100 odd bucks on the dyno and repeat
If someone fits your chip and the motor blows up because it detonates itself to bits or melts piston crowns etc will you replace the motor?
Who told you ????
Please give me my customer name.
Dyno operator check knock and AFR properly , engine never blow up .
Also I said if not happy I refund money.
Price is $400 for std turbo and dyno around $80-100.
Yes, around 3% need retune so some time dyno fee x2.
Power will get around 190-200kw AFR11-12 depend customer.
If he will go to race track I will tune to AFR 11.
  • Replies 63
Of course not.
The whole point is why get a mail order tune when you can just pay for someone to dyno tune it properly with knock detection and wideband logging equipment. You won't save any money in the long run and you will end up with a 'guess' tune that is far from spot on.
12.5 AFR at peak torque in a country like Australia where we see 40c summers? 'I think' isn't really good enough when you have a two thousand dollars worth of engine to replace if it goes pop.
Sometimes you have to beat a dead horse to get the point across.
Of course realtime tune is better. So Im asking to customer would you like to mail order or real time tune. If customer want to real time tune I will go another state for tune.
But some customer want to remove boost limiter (R&R) and do not want to spend over $500 for ecu.
Many people want to better power and response (not best) but do not want to spend over $1000 for ecu.
I think my mail order remap is good for like this customer.
Many people buy like a mins ecu but I think my remap is much safer.
Because my data is for Australia fuel.
I always explain to customer when hot day please boost down.
Also I told if customer will go race track I will adjust AFR around 11 depends on power. (Many tuner adjusting to AFR 12 so they say AFR11 is too rich but I think around 11 is safer for race track.AFR 11 is normally cylinder temp around 850 degrees)
I can tune for customer request.
If customer want to power I can do it but I will explain for risk.
If customer want to safe tune I can do it but bit lower power.
If customer not happy I never charge.
Who told you ????
http://www.youtube.com/watch?v=EbVKWCpNFhY
LOL
Im sorry about arguments on this thread.
I do not write much forum about tune before because tune is depends on tuner.
But I think we have tell best information on thread now.
Because many people thinking need a lot of money for tune.
I do not think so If its not full tune.
So This times my answer , 370 cc injector is able to make 250kw+ but if you want to go race track I think bigger injector is better.
If you never go to race track 240-250kw not problem.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
