Denzo from Japanese Motorsport has them on his car:
http://www.japanesemotorsport.com.au/denzo180sx.html
I imagine they can either get them or point you in the right direction.
Personally I think it would be a lot cheaper to get a copy, but I think you probably know that already :P
Edit: maybe also give dAVE on this forum a buzz as he can get Advans from Japan: http://207.44.134.160/rims/
Edit 2: manufacturer's website for the rims: http://www.yokohamatire.jp/yrc/japan/wheel...g2/siena_g2.jsp
Edit 3: (man I have too much time on my hands) -- if you can't afford the ADVANS, check out the Hyperfang II's here as they are basically a direct copy: http://www.speedywheels.com.au/Speedy_Alloy.htm
LW.
thanks 4 the info,
the main reason im asking is b'coz i have a set.
and i wish to track down a centre cap coz im missing 1
i bought them dirt cheap of a guy that didn't know wat he was selling!
frankly i didnt know wat they were either till a friend pointed out that they can cost up 2 $4000 a set.
bout time i got sum luck on my side.
gonna post pick of my car after a polished engine bay also in a new thread
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
