There is plenty of water flow through the top of the radiator, i just pulled the cap off with the water temp at 64 deg and started the car and there was heaps of water flow going through the top of the radiator.
It all started after the GTSS turbos went on. So Im considering just getting new water pipes for the turbos and see if they help at all, a set if about $60 on ebay. I cant see the turbo feed and drain pipes cauing the engine water temps to get that high but on idle.
Im getting cams in the next few months. So will be doing the 100000km service at the same time. Would an N1 water pump be of an advantage or would the std be better. Will get a new craig davies clutch fan aswell.
The impellor design of the Nismo should flow more water with the same effort but how much effect that would have on cooling is probably jack shit. Cooling the water is all in the radiator. Get a triple core.
It flows less water than the standard one so it doesn't cavitate at high rpm
i had a wierd issue with my car after changing the turbo so this is a long shot for you...
my tuner left the splash gaurd off the bottom of the car after i picked it up and wasn't until the following week i figured out the issue as the fan was blowing the dirt around on the drivway... i then got it put back on and the car ran cooler... just a thought.
Yeh I had the splash tray off for a bit and placed it back on along with the diffuser and hasnt made a stick of difference
BSA not really understanding where your going with that one, even if it was the stock thermostat it would still stay open in this weather. Also when the thermostat closes it allows the coolant to heat up quicker.
Edited by sinistaGTR
When I was looking at going to a nismo thermostat I did heaps of research there are a few opinions on them. Most people recommended to only use them for track use as some people had overheating problems when used on the road that's why I suggested it. I know I sound stupid but just sharing what iv learnt over the years
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
