R34 Gt Part Out
  • Replies 45
Posted Images
So guys want the parts out of my house asap so im willing to let things go alot cheaper
Nismo Sports Exhaust B0100 AA525 Full 3inch exhaust 3.5 tip incl cat $200
Rear Tail Lights $60 each
Seatbelts $30 each
ABS unit $50
Brake master cylinder and brake booster $50
Rear shocks and springs $50
Overflow bottle $20
Manual Dashboard $60 less then 100,000km on the clock
radiator $50
air condensor $50
passenger seat $50
rear seats $60
Mite negotiate more depending on the item/willingness for the person to buy.
Still have the car its self. If you want certain clips/ screws come down (Clayton South) and take them
0431188213
message if you want any other parts ill tell you if i have it or not with a price
Sold already:
Boot
driver door
Window motors
Clutch Fan
Climate control Unit
Wiper arms
Doors mirrors
few other items
im in the united states. i have an r33. i want to do an r34 conversion. i can get conversion fenders for the front but i need an actual rear clip from an r34 two door to convert the rear. would you be willing to ship parts here to help me out? i need a full rear clip but the rear quarters could be cut off and the rear cut off to ship smaller pieces? all i can find are four door rear clips and most people wont ship to the U.S. i really appreciate any help.
yer i can see what i can do. i dont understand what u mean by the the rear quarter section.
ideally some pictures and stuff would help
  • 3 weeks later...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
