Hi Everyone, there seems to a lot of EPA slips flying around and landing on windscreens and in letter boxes.
Question is which exhausts have passed and which haven't ?
There is plenty of different setups when it comes to exhaust and of course depending on whats done to the engine does have a huge impact towards the configuration of the exhaust setup,
So post which mods you have and exhaust configuration including the Db reading for each setup.
Example:
BMC filter
FMIC
EBC
PFC
split dumps > 3" down > 100cpi cat > 3" > resy > HKS HI power muffler
102 Db
running 210RWKW
All else stock.
I had a Kakimoto catback, 2 large oval mufflers and a standard cat, no chance it would have passed EPA, stock is really your only option on Skylines.
Stock GTR's are over 90 from factory, we are all F#$%#*.
and I thought my 3.5 inch racepace full exhaust was quiet...until it's opened up at 8k
My RP 3.5" (on the 31) is 91-92dB @ 5100rpm. So juuust about legal, but not quite.
Not sure if the GTR version was able to have larger mufflers to get it down further.
Either way enough to have a nice note, but not get attention :)
Well if it's over 90 from factory doesn't it make it legal because it's been complied?
There is a cut off date for the exemption, for instance a 67 Mustang can be 114db and get away with it, just not sure on the exact date.
I wish.....
older than I think it 85 are the older ADR's so we get 94db but that it.
Not to a legal standard whilst maintaining the flow of a straight 3.5" exhaust, decent CAT and acceptable ride height etc etc - on a skyline.
People including myself have been there and tried, you come close, but just not enough.
Another car with a different floor pan, then possible if you could get mufflers on there that are larger again... But 2-3dB is actually a substantial amount of noise to soften.
It's the noise of the motor and the 4700/5100 RPM that the tests are done at that sets the meter off. They also measure "back off" noise too, which often a crack/pop will set the meter off over the limit.
3" you can get passed however, as i said in post #4
So which 3" configuration do know you of that can pass
which dumps, down, cat, res, muff, material, press, brand etc.
The big question that follows is do you have evidence?
I just find it hard to believe that a stock exhaust system on an R is >90db or is that referring to a particular model - 32, 33 or 34.
The standard 34R system seems pretty restricted to me however, the only good thing about it is the awesome flow properties from the manifold and dumps. Do not change them :)
