Rb25Det Neo Injectors
Josh...
 Share
simon uses siemen deka injectors, the 3/4 length 60lb injectors are a direct fit but will just need to rewire new plugs. you can get this from the states the cheapest.
im runing 600cc high flows and havent had any fuel or tune issues. currently making 245rwkw and soon to be 300.
speak to PJ on this forum, i got them down thru him.
I was going to get the 80lb Siemen deka they're like $380 for the set.... Are they actually any good ??
You will be hard pressed to find injectors that don't require spacers to fit. Spacers are not really an issue, although mine came a little close to hitting the plenum. But I believe the Siemens injectors require different plugs to be fitted as the stock ones are oval and the Siemens are square. Or something along those lines, either way it didn't sound like a big issue either. My tuner simply told me to stay away from them so I did, but there's plenty of people on here who seem to be using them successfully with no issues.
Deatchwerks plug in with no mods, no rewiring needed.
and there cheap too!
More info to use.......Currently making 250rwkw with a GCG highflow on 17.5psi on stock injectors + all supp. mods and according the my greddy informeter I hooked up there maxing out and reach 100% duty cycle at about 6500rpm just before redline . But I never take it all the way so i'm fine with it :P
Siemens Deka 60lb high impedance short EV1 injectors on ebay usa for $279.95 - seller lpfdistributors. Doesnt say its top feed but looks like it is- cant post link here from iphone. Looks short enough not to require spacer kit so i assume just plug connectors required.
Is this the best deal around for R34 GTT injectors????
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
