Hi, just wondering how people care for their carbon fibre parts. my bonnet and grille are both carbon fibre. they looked milky and chalky when i purchased the car, with a little cut polish, they came up an absolute treat.
About three days later (in the garage) they have started to become milky again. what sort of polish or sealers do you guys use?
https://www.sau.com.au/forums/topic/384260-carbon-fibre-care/
You need to determine if the parts are finished in clear 2 pak, acrylic or gelcoat...
All 3 would need to be treated differently.
If you have purchased cheap china knock off parts they will be clear gelcoat, pretty much no way of stopping the milky finish. Due to the fact the clear gelcoats used have no uv protection, you can polish them and get them clear coated but uv will still penitrate and cause the gelcoat to go milky.
Only way of stopping this is keep your car out of uv light... or paint the carbon parts the same colour as your car.
Just get used to polishing the parts to keep them looking good.
sorry for the bad news.
Not True.
You can use a sealant such as cquartz or jetseal 109 which will help greatly!
Waxes and sealants are made TO PROTECT against UV damage and other damage and carbon fibre is no different in that sense. once you polish the CF use a couple of coats of a sealant or a coat of a ceramic sealant like cquartz and you will have no issues.
Its is the same with headlights people get these "kits" that have heavy sand paper and scratch the light to much, headlights from factory have a Uv protection layer on them, all the 800 grit sandpaper does is remove all of this straight away and leave it more vulnerable to future discolouration in future UNLESS you use a sealant reguarly or a ceramic sealant as mentioned above.
Key words there are greatly help..
There is a huge range of aerospace coatings that will help too. The problem is there is no permanent solution.
I could rattle on about why but hardly anyone would understand.
Best solution would be to paint the carbon parts with a suitable product that will be stable to the TG of the resin/gelcoat used.
To give you the simple understanding if your resin or gelcoat TG is 110 degrees C and you have left the carbon finish in direct sunlight, your nice pretty clear coated carbon part will easily reach 140 degrees C
So even if you think your nice UV wax or sealant has saved you it hasn't, your part can start to soften and start to break down.
Moral of the story, if your car is a dark colour your stuffed either way. If your car is white/silver or a much lighter colour, paint your carbon parts.
Or purchase some cquartz or jetseal 109 and get use to regular maintenance.
:thumbsup:
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
