  • Replies 40
Looks a little high, but that is not how Nissan gauges work. Basically all Nissan temp gauges will warm up to their normal running temperature, and sit there until the fluid actually boils (and you have broken something), and only THEN goes off the richter scale hot. Generally they don't move much inbetween.
But you should put a real temp gauge on every Nissan car imho - espeically one with a 95-100 degree warning light. Boiling cars is the 2nd easiest way to blow an engine (next to not enough oil/low oil pressure).
I put an awesome EL overlay over my cluster, and in the process of fitting it put my temp gauge out of scale - mine now sits between the 3rd and 2nd last lines when at operating temp (and already 1/3 way up when cold at start up). That's why I put in a real temp gauge
bleed the system, might need topping up. at that needle position youre probably looking at around 110-112degrees water temp. not the best, but is still operational.
if it doesnt have air in the system, look for a blockage, or check the status of your thermo fans. does it go back down when youre cruising again? if it doesnt, possibly a water pump issue.
Gosh...I and my mech didnt pickup this overheat issue when we do inspection before buying. Now it becomes annoying....
Do you guys think i should go back to Nissan dealer to have diagnosis checks? Or anyone can recommend any reliable mech in Brissy?
Thanks for you guys help~
or just check the fluid level so that you dont pay someone $180 to top up the radiator......
Did check fluid level is full & top water hose is not too hard to press, fan is only running when a/c is on but even a/c on, the temp is keeping in above middle line...what eles i should check by myself?
Your thermo fan should come on even when the a/c is off, once the car gets hot enough.
I would be checking for air in your system (which I bet is the cause). Or get a mechanic to install a water temp probe and actually check your water temp to see if your stock gauge is lying/broken.
Just found your question when i was a bit panic, sorry, mate~
I havent flush the coolant yet, but will do soon.
What do you mean by "doesnt have air in the system, look for a blockage" how to check it? I check my fan only runs when a/c on but it doesnt go back to normal temp even with fan (a/c on) on or when i am cruising again.
Water pump issue? What other procedure that i can check whether it is water pum failure? Pls advise, thanks~
Thanks, Andrew. How can you check air in your system?
Unscrew the little plastic bleed screw in the left hand side at the rear o fthe engine. If you look along the water piping you will see it - it is black plastic and has an X in it to unscrew it with a phillips-head screwdriver.
Hi Mikhail, so have you ever checked by Nissan or any V35 SERVICE SPECIALISTS before? Or you just leave it as it is?
I am leaving mine as is as I am pretty certain its normal. I think I saw a similar thread on here that said the same thing. I had mine serviced and no problems were found. Also my needle is just below the middle, yours is above middle.
If you have access to someone with a datascan tool, get them to check the coolant temperature with it, if it is around 85-90 deg C, then I wouldn't worry about it. Especiallly if it doesn't seem to go up and down when driving hard, or climbing hills
I wrote a proper bleed procedure somewhere on G35, just search my name.
Also get a radiator cap with temp control gauge on it, you can go check yourself.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
    • I said "Matlab clone". I could throw one onto one of my linux VMs. Probably only take 10 or 20 hours to sort out the dependencies, relearn how to use it, etc etc.
    • Hi all, got myself a 400R end of last year. Few tasteful mods done so far. Love the thing. Has anyone got any suggestions for sourcing bodykit parts for them over here???
