  • Replies 5.5k
Posted Images
also, for your enjoyment
the new mclaren front end
ver nice. LM-style vents over the front wheels are cool. can't say I've ever liked those optional wheels, but nothing a set of HRE's or similar wouldn't fix.
75hp is a not-inconsiderable increase. would run sub 3 sec to 100 for sure with 667hp and some corsa tyres.
at 660hp+, 1400kg, with 200mph+ top speed, 3 second 0-60 and a price tag of £168,500... this is the car to have
bang for buck, its almost unbeatable
except they are only making 5 of the HS models to keep them exclusive :blink:
Speaking of collecting shit
A lot of teams are selling their 2011 apparel and merchandise at a massively reduced price if anybody is interested. I know Mclaren is 50% off almost everything... sh@un...
which sites do you recomend for cheap merch
Is that at a specific shop? RBR prices all seem the same
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
