  • Replies 5.5k
Posted Images
they're a lot cheaper now than when i looked last year.
just noticed you're from newcastle, it will cost a bit more for you.
my flights last year cost $168.
i got the cheaper ticket price from Tiger Airlines and got Jetstar to price match by 10%.
Good idea, did not consider. Will do for future.
Baggage as well?
We ain't staying in a back packers either.
We aren't either.
If you're inferring because we bought cheap tickets, we are therefore staying backpackers... :domokun:
We will be walking there, thats all i know.
On the note of all this, two weeks until our group will be at the airport boarding!
when i looked last year the airfares where like $800 for two.......
from Syd to Melb, or Newy to melb?
If Syd to melb, theyre ripping you a new hole.
who did you get the quote through?
Baggage as well?
they charge the baggage fees off competitiors price theyre beating.
You dont stay in Monaco, you stay in Nice and you catch the train in everyday. Get on early
Depending on how much fun you want to have, the hostels there are great, because everybody else is doing the same thing as you. Even all the cute girls
You'll pass the place i want to retire in on your train journey. Make sure you stop there and walk around, its utterly magnificent
You buy a different grandstand ticket for every day. Here your one ticket get you the same seat for four days, over there, you can buy a seat in a completely different end of the track. Like i did. I can PM you the best spots with TV's, because the track maps on the internet are bullshit.
Friday is an open day, i massively recommend walking the track, its all completely open to the public. The pits, the harbour with the boats, everything. The photos you get are unbelievable, the team operate 2m in front of you. I even met Jackie Stewart!
Don’t worry about having to bring food, there’s heaps there and its all cheap. The baguettes are 4 euro and its like they were prepared by restaurants, not Indians on uni holidays. No need to pack anything but sunnies, hat and maybe something to read.
... theres so much more, but im supposed to be working, so perhaps later
Holy shit. Awesome place to retire!
Thanks for that info!
It is pretty rad isnt it
Theres a shit load more info about seating and moving around too
qantas? big spender!
$317 return for Qantas for us. Because Air Aus screwed us over. Hopefully get money back for that though.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
