  • Replies 5.5k
Posted Images
shame for Williams and Maldonardo. nasty hit!
Good to see the right man from McLaren won!
RBR had surprising race pace. Looks like being a good close battle between those teams this year.
Hats off to Alonso dragging that dog Ferrari home in 5th. They've got some serious catching up to do, yet again... Seems they've swapped places with Mercedes from last season. Maybe even further down the field in reality.
Man its tight between a whole lot of other teams!!! Bring on next weekend :)
I have had problems in my life. But next weekend, having to get up at 6am in Belgium to watch the Malaysian GP, just in time to walk out the door of the Hotel to cut laps at Spa in the Caterham? Thats not a problem I mind having. :ph34r:
Caterham seem a bit quicker and close to the tail enders, but they are really in limbo. Nowhere near STR/Sauber/Williams but well ahead of the Marussia/HRT. Disappointing that their cars are still unreliable :blush:
was a great race (from what little amount they showed). plenty of close battles all the way through the pack.
glad to see massa off to a great start by finding someone new to run into and scoring a DNF.
would've liked to have seen where Dan would've finished if he hadn't had to pit on the first lap for a new front wing.
Why has Ferrari kept Massa and not just paid how his contract and sent him packing? What do they owe him or what does he have over them? They should have dropped him when he got smacked in the head!
my guess is that they feel bad about him getting smacked in the head
just saw that the 2011 tour de france coverage by sbs has been nominated for a logie for best sports coverage. no surprises there really given that during the 3 weeks of racing they probably have less ads than what channel 10 showed today, and only talk to people who know what they are talking about.
And brilliant commentators who make you hate going to toilet/to eat etc. Anything that makes you leave the couch!
If Perez keeps driving like he did today! Massa could easily be pushed aside mid season and Sauber grab some other rookie or blood
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
