  • Replies 5.5k
Posted Images
4 days on Fangio grandstand.
Not sure if I want the stand, so may sell off and move stands if I can be bothered.
Being on Jones was pretty good on Sunday.
Brabham was pretty good, but the afternoon sun would be hell during the main race.
We got it for Practice but overcast the whole day which helped.
Clark was terrible, pretty bad view. In the open, whole day of sun.
The grass mound on the left would have provided better viewing.
we were in Brabham but ended up viewing from the Johny Walker bar platform and off brockies hill turns 9-10 and into 11 for some of the suport races. mixing it up was definatly a good option. the sun was a pain but wasnt a big drama for the race. was suprised how effecient the trams were by sunday. friday was by far the worst day for trams.
very pissed with the orginsation of the GP advantage pit walk. as were plenty of other peope we bumped into. missed it due to no one haveing any idea where to go. was in the end told the wrong spot and waited there for half hour. was suposed to get a detailed email regarding details and never got it.
was a good weekend with plenty to see and do at the track. not sure id rush back next year thoe.
Brabham was hard work looking into the sun on race day.
Jones definitely the better stand since you have the sun behind you and can see part way down the main straight as well as turn 1/2.
Schumacher stand is actually really really good. screen right infront of you, can see the final two corners, pit entry and most of the front straight.
Or the Waite stand at the high speed chicane, excellent value for money, plenty of action and right next to all the food and entertainment
Saw turn three has a stand too now, but its a bit far away from everything. Good action on track though
what. to. do.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
