  • Replies 5.5k
Posted Images
Bieber with a commanding quali lap comfortably on pole.
was really surprised at that given how close the rest of the qualiy was
Q2 was edge of the seat stuff with the top 6 covered by less than a tenth of a second!
If only this track provided racing as exciting as that!
hopefully Koba or Romain can get winner no 8
Mark Webber labels his qualifying issues in Valencia as a "big hit"
Mark Webber described the DRS problem that wrecked his European Grand Prix qualifying session as a "big hit" for his championship chances.
The Red Bull driver will start only 19th in Valencia due to the issue. Webber had earlier run into technical problems in free practice as well.
"We had no DRS. That's worth 1.3 seconds, so it makes it very difficult when you have no DRS," he said.
"The car's put up a big fight today. We've only managed four laps all day, and three of those were in qualifying.
"We had one lap on primes at the start and then went to the pits because the gearbox hydraulics were playing up.
"The guys did the right thing by putting me onto the options because we were in a desperate situation there to try and get through because it's very tight.
"The laptime wasn't too bad given the DRS was out, but it doesn't do anything to help our situation. So now we have to do what we can tomorrow."
Webber admitted that the Valencia qualifying result could prove costly.
"It's a big hit for us," he said. "With this one and Barcelona, that's two difficult qualifyings through no fault of my own, but that's the way it can go over 20 races."
http://www.autosport...t.php/id/100624
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
