  • Replies 5.5k
Posted Images
  On 08/07/2012 at 11:41 PM, tweety bird said:
Antone else notice the guys on either side of the middle of the car wearing what looks like fire extinguishers are also holding mini sledge hammers?
  On 08/07/2012 at 4:50 AM, tweety bird said:
i've never noticed the second intake before.
The Gearbox and KERS coolers are located down the back of the car and are fed by this duct.
  On 14/07/2012 at 11:47 AM, ctjet said:
I'm not as much of a Vettel hater as others seem to be, but I thought he was quite likeable on Top Gear
Marussia has ruled out a problem with its car as the cause of Maria de Villota's recent testing accident, after concluding its own investigation into what happened.
Team principal John Booth said: "We are satisfied that the findings of our internal investigation exclude the car as a factor in the accident. We have shared and discussed our findings with the HSE for their consideration as part of their ongoing investigation.
"This has been a necessarily thorough process in order to understand the cause of the accident. We have now concluded our investigatory work and can again focus on the priority, which continues to be Maria's wellbeing. In that regard, we continue to support Maria and the De Villota family in any way we can."
De Villota is now out of sedation in hospital and able to talk to her family as she continues her recovery.
http://www.autosport.com/news/report.php/id/101236
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
