  • Replies 5.5k
Posted Images
Talk about taking things out of context guy.
let me replay it for you... emphasis mine.
tjet, on 17 April 2012 - 09:32 AM, said:
I hope it does
Will more than likely push ferrari further down the WCC order with their distict (sic) lack of point scoring ability
and hip-hip-horay for that
snapback.pngsh@un, on 17 April 2012 - 12:42 PM, said:
Ferrari total 37
Nando 37
Massa 0... :ermm:
snapback.pngJAS-25T, on 17 April 2012 - 02:06 PM, said:
Somthing (sic) similar could be said about schumi
let me replay the first sentence for you...
"except that before the last race, it was only Schumi who had scored points for Merc this year."
where's the similarity?
Edited by hrd-hr30
Interesting, will they favour webber now?
Of course not, he is the driver essentially on the out. Unless after 3 more races and Web's is higher in the points scale and performing better etc - then it'll still favour Vetool.
Don't forget that Web's has only really risen back to the spotlight so to speak because Vetool is not performing, combined with the flat tyre etc. I think it's still way to early in the season for RBR to make Vetool play 2nd fiddle. If only Webber could start a F1 car as good as other drivers, the start hurts his entire race. Imagine he started well like all other drivers from his quali positions, would be a much better first lap out as being mid-pack has so much risk with being taken out!
I don't think its a case of Vettel not performing. Its just back to 2010 where Vettel didnt really like the balance of the car and often Webber had a pace advantage, equally as often Vettel had a slightly better setup and pace. Remember up until the introduction of the blown diffuser in Hungary 2010 Webber had won more GPs, leading the points and had every bit of the quali and race pace Vettel did. BUT, come Hungary with the change in the blown diffuser Vettel instantly was a few tenths quicker. Webber won in Hungary because Vettel goofed...but it was clear Webber struggled with the car compared to Vettel. That continued all the way through 2011.
Now, no blown diffuser and its interesting. Webber is a long way from dominating Vettel, but its clear he is back on the pace of Vettel and to date he has just had a little more fortune then Vettel so in turn is ahead on points.
I look forward to the car development this year. I hope to see RBR get a bit more quali pace as if the are to be a hunt in the WDC they need to be on the front two rows for the race and solid podiums week in week out. Otherwise McLaren will just grind away and walk away with the WDC/WCCs
I think that's pretty much on the money Roy, Vettel and the EBD we're made for each other it totally suited his driving style, not so much for webber. Whether both sides of the garage shared all there of throttle maps I don't think we would ever know for sure, but that's tin foil hat stuff anyway. The most pressing issue is getting the drs front wing f duct onto the rb8 because it seems looking at rosberg in china it's a huge advantage for tyre management to have pole.
Yeah, sounds about right.
Definitely too early, long season ahead, anything is possible.
you should. the only reason Schumacher hasn't been in the points more often is mechanical failures, which forced his retirement from 2nd and 3rd. There's no similarity between that and trundling around in the back half of the field while your team mate scores all the points. In fact, last weekend was the first time Nico had been ahead of Schumacher on merit in a race this year.
Edited by hrd-hr30
anyway, looking forward to this weekend. The hotter temps will be a good test of whether the Merc's race form was just down to the cooler temps in China or if they've actually sorted their rear tyre degradation issues.
outside of something strange happening, The Merc will be out the front again, and with no traffic to content with, i cant see why last weekend wont be repeated
Unless they slip into the pack it looks like a merc powered white wash to me
hopefully the iceman gets his stratagy sorted and we see him bumping wheels for a podium this week
if he stops drifting every corner he might have a chance...
RANK TEAM NAME POINTS 1 1 au.pngWebbull 183 2 1 au.pngSau 166 3 3 au.pngNubs's army 125 4 1 au.pngNJSracing 116 5 2 au.pngJteam 112 6 2 au.pngstR33ter 109 7 1 au.pngKimiUmp 108 8 1 au.pngDori34Racing 102 9 2 au.pngLooptrooop 101 10 1 au.pngFishos 97 11 1 au.pngMissileman 89 12 4 au.pngMacGillaZ 81 13 1 au.pngScottydoo Racing Mega Predictor 74 14 au.pngScuderia Dezz 73 15 au.pngSniper Racing 71 16 3 au.pngN1GTR 63 17 au.pngmad082 27 - au.pngOZHCR32 0 - au.pngSMc_F1 0
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
