  • Replies 5.5k
Posted Images
  On 30/04/2012 at 8:47 PM, Roy said:
Its 2010 again when after Silverstone there was talk that Webber was off to Ferrari. I doubt it but would be a cool way to finish up your F1 career
http://www.planetf1....Perez-stop-gap-
imagine if webber did go to the fez. would lead to possibly the best team mate racing in F1 for a long time. i don't think the team bosses would like a repeat of Eau Rouge from last season though
anyway, back in 2012
Mclaren have tried to secretly test a new nose in Mugello
Oddly, they only used it for in and out laps, in the hope nobdy would notice. Theres absolutely no mention of it on technical forums or websites, which is strange as its a decent change in philosophy for front end aero.
Left is old, right is new
  On 08/05/2012 at 3:48 AM, N1GTR said:
Oh the noise up that famous hill.....
And the old layout seems more of an adventure. Gutted it changed before I got there
Webber has always gone well up against Vettel in Spain. Here is to hoping he can edge Vettel and others out and start a nice little patch of victories and podiums. I am tipping RBR this weekend to be strong along with Lotus...McLaren will struggle again is my tip
the new nose gives me the impression that it may have a bit of flex to it. probably won't, but for some reason that curved look just makes me think of flex
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
