  • Replies 5.5k
Posted Images
That's because they didn't show him on airtime at all for whatever reason, had a reasonable race by the looks of it!
Reasonable race overall, lots of stuff ups still with penalties and pit issues.
Also interesting to see the RBR team with a clear issue with the front nose cone.
No-one seriously hurt I trust.
Glad the fire didn't start during the race.
Someone at the celebratory dinner has got to say, "Pass da pasta Pastor"
From best previous performance of 8th > 1st now is great news & great driving.
Williams working to determine cause of fire, FIA says 31 people treated in total
It is so far confirmed only nine members were from F1 teams but other team personnel were understood to be involved.
Caterham said four of its members had been taken to the medical centre for examination, while another Force India mechanic had also suffered from smoke inhalation and was under observation.
Formula 1's ruling body, the FIA, said a total of 31 people were seen by medical staff from the circuit. Seven had been transferred to local hospitals.
http://www.autosport...rt.php/id/99605
no one seriously hurt that we know of terry.
nice to see people form other teams helping them.
PS Pic 4:- Those red hoses need reinforcement in the walls, since they kink badly
Aren't those lay flat hoses? THey store flat on a reel (take up less space) and only fill out when they've got high pressure in them. If so, those kinks will do nothing to stem the flow. The hose is flexible enough to allow the water through, even with the kinks in them. The amount of water they flow is overkill anyway (if you have good pressure) so the small reduction in flow won't make a big difference to their firefighting needs.
Thanks, I'll accept that; but the same hose in Pic 3 seems to be emitting better flow (notwithstanding that the pressure + the nozzle position are the same).
Overkill? In this instance, you're probably right. Ta.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
