he was only off the track because Hamilton forced him off...
if you squeeze someone that hard, you have to realise it comes with a risk of collision.
The whole situation was caused by Hamilton, who had no chance of hanging on to that position anyway.
Exactly.
Hamo's arrogance kicked in as usual - and Pasta did what he does best.
Hamo was going to be overtaken anyway, he knew this - so just give up, take the loss of position and don't miss out on any points.
His post-race kinda summed that up the way he avoided the question "i dont remember". cops arse he didn't. He remembered exactly and new he had a part to play regardless of who was "as fault" as determined by the stewards
  • Replies 5.5k
Posted Images
No way.
Hamilton was brilliant there (I hate hammy). Shoved him off the track leaving zero room. You either yield and slot back in to overtake elsewhere or crash. Most drivers have the common sense not to crash... He only had 1.5ish laps to go? Sorry but if I was in Hamilton's shoes I would've done the same and defended like crazy.
don't the 2012 regs read that you must leave a car width available? Hamilton drove Maldenardo off the track, and Maldenardo hit him. IMO they both should get a penalty
I think the rule is along the lines of they are only allowed to move once to cover an attack, they cannot repeatadly attempt or something.
It was raised in i think Shanghai or KL
he can run him out of room on the exit, under braking is where the new rules stop people like schumacher chopping you off the track
Hamo did the right thing and pushed Pastor wide as he had the racing line, Pastor refused to accept the failed attempt and brain faded for a fourth time now, taking out Hamo and himself by hitting him in the rear of the coke bottle
What hamo was doing by keeping him behind is what called racing, what pastor did is called gp2
Pastor kept his foot in it, while off track, and had nowhere to rejoin BUT into the side of his opponents car. Total and utter balls up. Yet again
Is he far enough up the side for Hamo to leave him a car width? It kinda looks like he was.
If Maldonado didn't back out at the apex of the first turn then it was always going to end in tears when Hamo turned into the apex of the next corner.
the rules actually say "deliberate crowding of a car beyond the edge of the track is not permitted"
very harsh to penalise Maldonardo IMO. Penalise both or neither.
Edited by hrd-hr30
what was truly appalling was how Senna was penalised for the contact with KK
Agreed, was quite surprised to see him get a drive through for being driven into.
How did you feel about the defending that Rosberg did a few races ago (can't remember which track :blush: ) on the straight?
Hamilton had the racing line...Maldonado was never going to make that pass around the outside into that corner, so he should have yielded and set himself up for the next few corners.
He would've passed him no worries, but he got impatient and drove straight into him instead.
As Ivan stated, it's called racing. If there was 10 laps to go Hamilton would've more than likely let him passed without a fight as he would've lost time defending a position he was never going to keep, but with a lap and a half to go, any race worth their salary is going to defend hard.
/thread
i think this was covered slightly a bit back, but didnt anyone else notice the way that webber in his pre-race interview felt like he was swaying towards fezza team.
if he went number 2 there i beleive he would be taking a step backwards. number 1 driver or bust........
Better find himself 3 WDC titles...
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
