  • Replies 5.5k
Posted Images
Having enjoyed two days of testing in Valencia, former World Champion Kimi Raikkonen is feeling "very positive' about his return to Formula One.
The Finn spent Monday and Tuesday driving a 2010 Renault R30 at the Circuito Ricardo Tormo in a private testing session. The Lotus driver got 171 laps under his belt as he reacquaints himself
with an F1 car after two years on the sidelines.
"It went well today and overall the two days have been helped me a lot," said the 32-year-old.
"Having not driven a Formula One car for two years and obviously with a new team, there is a lot to get used to. I'm happy because I was pretty quick to get back in the groove."
"Even though I was using a two year-old car and the Pirelli demonstration tyres, I learnt about working with the team and the engineers which means I can focus on the new car once we get to Jerez for the first official test.
"It was great to be driving an F1 car again and from that respect I feel very positive."
Having admitted after Monday's running that he was highly impressed by Raikkonen, Lotus' trackside operations engineer Alan Permane was pleased with how the 2007 World Champ upped his game on day two.
"We enjoyed another good day with Kimi in Valencia," he said.
"The morning was spent doing set-up work in particular with front and rear cambers. In the afternoon we ran very low fuel qualifying simulations with two new sets of tyres followed by a 27 lap run starting with a full tank of fuel.
"Kimi's pace improved from yesterday as we would expect and we completed several start, pitstop and clutch simulations. We were even able to finish early as we completed our programme ahead of time.
Overall it has been a productive and valuable two days."
http://www.planetf1....-Test-A-Success
Edited by tweety bird
"Sadly, it doesn't make the FF look any better"
oh the lulz
what a pig ugly panamera look-a-like
oh the lulz
Oh you'd better believe I laughed at that comment too!
They have a quickly growing McLaren section too.
Nothing beats the photo threads though, easily the best available
... oh sweet jesus what have caterham done
we can only pray to allah that this doesnt work as a concept, the last thing these cars need is to look even uglier
that hump up the nose will produce a small amount of pressure at the point of the front suspension, but can't see it making that much of a difference!
hmm maybe time to make one up and run some simulations :whistling:
ruben's going to race in circles.
According to The Associated Press, anonymous sources have revealed that the 39-year-old will be behind the wheel of the new Dallara DW12 chassis at the Sebring International Raceway for two days next week.
http://www.planetf1.com/driver/18227/7456663/Rubens-to-break-promise-with-Indy-test
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
