Josh... Posted November 28, 2011 Share Posted November 28, 2011 Just installed gfb stealth fx on my 34 but the trumpet won't fit on because of the stock boost guage nipple right there ! Any quick fix ? Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/ Share on other sites More sharing options...
Hanaldo Posted November 28, 2011 Share Posted November 28, 2011 Return it to stock? Seriously though, I would suggest bending the nipple a little bit? How much does it foul by? Perhaps a spacer plate is in order... Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6130485 Share on other sites More sharing options...
Josh... Posted November 28, 2011 Author Share Posted November 28, 2011 Bending the nipple was my first thought but I'm worried I'll crack the alloy ? Do they screw out so I can vice heat and bend it ? Also I can't help myself with the wank factor of venting Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6130514 Share on other sites More sharing options...
Hanaldo Posted November 28, 2011 Share Posted November 28, 2011 You'll get sick of it How much does the trumpet foul by?? If it's only a little bit then I would just try to slowly bend the nipple. If it's a fair bit then I'd say you will need a spacer plate. That nipple doesn't screw out, it's part of a plate that goes underneath the crossover pipe, looks tack welded on. Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6130959 Share on other sites More sharing options...
KiwiRS4T Posted November 28, 2011 Share Posted November 28, 2011 Stealth and trumpet ...surely an oxymoron?! Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6131002 Share on other sites More sharing options...
tridentt150v Posted November 28, 2011 Share Posted November 28, 2011 Stealth and trumpet ...surely an oxymoron?! You hide it behind the elephant!!! Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6131067 Share on other sites More sharing options...
Josh... Posted November 28, 2011 Author Share Posted November 28, 2011 Fair call I'll get the pliers out this Arvo and give it a bend see how I go if not I'll get a spacer plate made.. Never thought about it like that it does sound rather stoopid ! Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6131091 Share on other sites More sharing options...
Josh... Posted November 29, 2011 Author Share Posted November 29, 2011 Sorted :-D Link to comment https://www.sau.com.au/forums/topic/384303-stealth-fx-trumpet/#findComment-6132055 Share on other sites More sharing options...
