Hey guys i have just bought a 1993 R33 skyline. It has around 180rwkw it has the following mods. Turbo back exhaust, front mount intercooler, POD filter, boost controller at 9 pound boost. Im after 250rwkw or somewhere in the 12second bracket what do i need to do to get there? It currently runs depending on driver high 13's low 14's.
Thanks guys !!!
https://www.sau.com.au/forums/topic/384309-r33/
You need:
Upgraded turbo ($1000 to $5000)
Upgraded injectors ($500 to $1200)
Z32 AFM ($250 to $350)
Fuel pump ($200 to $600)
ECU ($1000 to $3000)
The above price ranges reflect the range between used or highflowed items and new and custom items.
Suggestion:
Hypergear highflow (tell him you want 250kw and to use the stock housings)
Used injectors (S15 440 or Nismo 550-740)
Walbro or Bosch 040 fuel pump ($200 new)
Adaptronic ECU and tune (about $1600? Hypergear can supply this for a good price with your turbo and you wont need an AFM)
Thread closed, if you need to ask questions about the above - search.
https://www.sau.com.au/forums/topic/384309-r33/#findComment-6131113
