  • Replies 48
Errr, you are having a joke  :Oops:
White smoke form your exhaust, suggest moisture, nothing else. Where that moisture is coming from is the source of the problem, and not necesarily the pistons.
its not a joke and thats what we thought moisture when we first seen it but couple weeks later it got worse and wose....
it smells like burning oil... i'll post a pic of what happens when piston number 6 doesnt have compression, it leaks oil and goes throught the turbo intecooler, actuator, intake etc: and when it goes throught the turbo the turbo is hot and it burn is which makes white smoke out the exhaust.
it is no fault mate..
one mechanic told you it's a design fault and you think it's true?
as mentioned, if it was a fault, then why was it used on the R34 GTT.. and all the way up to it's last build date of what.. 1999?
there is nothing wrong with the design of the RB30, 20 red top, 20 silver top and 25...
sure they differ a little from one another but as you can see, they all have the throttle body in the middle of cylinders 3 and 4...
just have a look at these forums to see how many guys/girls have the stock plenum and running huge numbers.
look at the gibson racing team red top rb20 using stock plenum and some ridiculous numbers..
the only fault of the stock plenum is that is isn't as pretty as front facing..
By the way i was talking about stock engines. gibson racing team ? they most likley have forged pistons in their which can handle detination an they proberly have it tuned right, but with the standard ecu, internals, intercooler etc:
you'r got more chance of looseing a piston then a rubilt motor. thats why i mentioned it beause guilty beause he's got a stock engine. which means its at more risk of detination etc:
that's a cheap pump i'd be going fuel pump then front mount then avc-r...
my advice!
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
