Hi guys,
I know if you buy a car which is older than 6 years, or you register a car from interstate, or your registration has been expired for more than a year you need a roadworthy.
But, is there any other time?
Sort of like how UK has the MOT system where cars older than X amount of years need to get checked every 2 years
https://www.sau.com.au/forums/topic/384320-roadworthy-certificates/
Spetz I dont really do understand.
The cop who gives you the defect can either choose to write down that you have to go to Dickson or not. They either say you go there or another station or one of your choice from what I know
When my car got defected, the cop ticked that I can take it to any inspection station as it was a minor defect. So I went to an inspection station in Fyshwick and the guy started looking over the car etc, then eventually looked under a hood and realized the car had an engine conversion, at which stage he gave me the papers back and said it has to go to Dickson because a car with an engine conversion is classed as "modified" and HAS to go through Dickson each and every time.
The wording of the RTA.ACT site is Crap and very misleading.
Modified cars, will mean cars that are required to have an engineering cert, Spetz as you found your lancer falls into that catagory.
there are two types of modifications
Basic/Minor/Common mods - ala exhausts, wheels etc etc (not including turbo upgrades) can be done at any approved inspection station
and
Extensive/Significant mods - ala engine swaps, brake upgrades etc etc that require an engineering cert will need to go through Dickson
My advise, make EVERYTHING look as standard/Factory as possible, if possible
Edit - See here
http://www.rego.act.gov.au/assets/PDFs/Light%20Vehicle%20Modifications%20in%20the%20ACT.pdf
and here
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx
Well I will need to go over the pits regardless and get an engineers certificate as they no longer accept my NSW one.
I was mostly curious as to whether I need to return every 1 or 2 years for a check up
Thank for the help guys :)
