hey guys i was looking at my engine bay tonight and thinking how to clean it up a little. now im running a microtech which is Map sensor so no afm and it doesnt use the aac icc valve. now the big hose that goes from the elbow of the crossover pipe to the plenum/aac valve. now i dont think the aac valve is in use as theere is no plug plug into the purple plug on it. can i remove this pipe and blocke it off as im soon to be running external gate off the stock manifold and this hose may get in the way a tad.
https://www.sau.com.au/forums/topic/384322-piping-for-aac-valve/
  • Replies 47
Posted Images
I would keep it there untill not needed. I mean run your piping similar to mine that way there is no mucking around blocking stuff off. What about front facing plenum? Totally get rid of all the clutter
thought of that but for the power im going for its not needed plus ill need to remove all my battery and redo all my piping its in a vl btw
That is true I'm just lucky on those kind of things. You found anyone over there to make you one of those manifolds. I'm mucking around trying to see if the wastegate can be fitted under the manifold and turbo get it out of the way a bit also keep it looking low key on the stock mani
yeah the boys at ovaboost can do it for me however let me know how you go for the low key side of things as im using this for street however i wouldnt mind seeing a external gate sitting there haha
eventually ill get a forwrd facing plenum JD customs ( a advertiser on calaisturbo makes a forward plenum for rb25 that bolts onto stock runners
As for the hose spigot, if your AAC isn't utilised then block everything up.
As for the plenum, I had a custom one made using a GTR plenum chamber and stock RB20 runners (RB25/30 with an N/a non-vct head) and a Q45 t/b on the front positioned so that I could utilise the standard GTR cooler/plumbing I fitted up. No relocation of battery etc. Barely cost more than a FReddy manifold.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
