Z32 Vs Q45
Josh...
 Share
There are clones or dodgy ones out there. Mine wasn't.
I have used a Q45 with my powerfc for years. At 315rwkw it was no where near being maxed out. I was running a GT3076 at 18-22 psi. I'd say it had about 380 - 400rwkw in it.
The benefits are that it has a larger diameter which means less restriction.
My turbo had a 4inch inlet, and I didn't see the point of reducing to a z32 size, so I bought the Q45. Was very happy with the results.
its for sale if you want it. Car was parted out and it was running my RB25\30 before we took it apart. Has the Plug and all. Let me know if you are interested.
(Im a tuner too... so I did all the tuning etc and I can guarantee it worked 100%)
Edited by The Mafia
I know z32 is tried and true but the q45 is a 90mm ? Which are better ? I've heard z32 has more resolution even tho it's a smaller body ??
You sure you are not confusing resolution for maximum measurable airflow? Generally, the higher the max flow, the lower the resolution.
Being an AFM for 4+ litre V8 one should expect Q45 AFM to have poor resolution, particularly at low rpm, but this is not a big concern on a RB25.
As for which one is better - it depends on what turbo you're going to use. If it's something small, say, hypergear bolt-on proposition, then I'd say stick to Z32 AFM. If it's something big, and with 4" inlet, then you could really benefit from higher ID AFM, so Q45 is a good candidate. It also depends on who will do the tuning.
Mafia, what P/N does your AFM have, is it -61U01 or -61U00? 4-contact plug?
Legion as you would know from my other many recent questions it is indeed a hyper gear turbo :-) it just seems that you can get the q45 for much less than the z32 and i know I won't max out a 32 with the hyper gear but I may upgrade turbos later...... Would there be any downfall to using the 45 now incase i upgrade later ?
spend the extra $100 tops and get a brand new genuine z32. support more power and have a more linear voltage scale, which makes light load tuning and therefore economy better. if you making enough power for a 3" afm to be a restriction then your past the point of being able to use afm's anyway.
Brand new the cost is roughly the same for either one, and JonnoHR31, although I somewhat disagree with the last sentence in his post, makes a very good point about easier low load tuning and economy. The limit of the Z32 AFM is approx. 580 bhp, and its ID is rarely a major restriction, as it has been proven by lots of results in RB25 dyno thread.
What AFM exactly do you have though, that's the question. These is another member here, his nick is Dangerman (or something like that), he had RB boosted by GT35 and mass flow measured with q45 AFM, he was quite happy with his AFM, but there was a bunch of other dudes who had no luck with Q45 and reported them to max out at roughly 270wkw.
So it would be nice to know if ther is a distingushing feature, an indication that would allow us to tell a higher reading AFM from an ordinary one.
Dangerman's was brand new, had a four pin plug and a P/N 22680-61U01. What's the P/N of yours?
Quick internet search informed me that there are Q45 afms, both with yellow sticker but with 2 slightly different P/N's, one's -61U00 and other is -61U01. The first one has 3 pin plug, the latter has four pins and that's the one Dangerman used. That makes me suspect that -61U01 may be the higher flowing AFM, and U00 is the "bad" one.
IIRC I have the 3 Pin plug version of the Q45 AFM on my RB25/30 with a GT3076R.
Making 256 RWKW (some power issues up higher in the rev range) with no issues down low regarding "resolution".
I have been told by my tuner that I have plenty of AFM left to work with and we are FAR from maxing out this AFM.
Once I get my car back (today) I'll post my P/N as a reference.
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
