Hey guys, Went to start up the gt-r on sunday morning to find the batery was completly dead after just being replaced last month.
I have connect up the meter and a light bulb and yes, there is a constant current being drawn from the BAT 10 amp Fuse, this is highlighted in WHITE on the fude cover lid. But i cant read jap so i dont know whats draining my power. The light bulb does not shine at a consistand brightness but, dimming in and out if this means anything.
taking the fuse in and out everytime i drive the thing is begining to become a burdon. It's an R33 model 1995.
Hope you guys can help me or throw some sudgestions to find were this power is being sucked from.
Cheers.
https://www.sau.com.au/forums/topic/38437-electrical-proplem-with-the-gt-r/
Cheers.
Are you referring to the japanese writing on the fuse box cover inside the dash?
This fuse layout is that I know from R33 GTS-t, but I think it applies to all general R33 including GTR. Hope it can solve your problem.
Car will not start. and the the battery go's flat is whats happening
interior lights still work, alarm and everything is running. and no its not the alarm!
Thanks for that translation mate and acording to that it's the Electrics Fuse.
odviously then its somthing to do with the elecrics of the car... so this eliminates anything else with a fuse and whats left?
And after inspecting the rear strut tower brace, the nut has been cross threaded and used before... so previous owner has odviously had battery out before afew times as well.
maybe i should give supercheap's head office a call and hassle bob, see if he knew what the problem was.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
