Hi people,
just about to install the aftermarket coolant temp sensor and gauge.
Just wondering, which radiator hose should i install it in? the top one or the bottom one?
iv got no idea which way the coolant flows in those hoses n am sure it would be important with regards to which hose i put the sensor in...
https://www.sau.com.au/forums/topic/384381-installing-coolant-temp-sensor/
thought so. cheers again peeps.
Also is there any way to ascertain if the thermostat is working right?
my car runs fine and normal and doesnt overheat but i notice if i drive on a really cold night the temp gauge goes back down quite low. (if normal operating temp is the usal dead flat 90degrees of angle on the dash temp gauge, or just below so prob 85 degrees of angle, id say when it is cold it drops down to about 70 degrees of angle)- see diagram
Is this normal or perhaps is my thermostat sticking open and therefore letting too much cold water flow through?
the stock gauge isn't that accurate. it will sit in the middle of the gauge over about a 15 degree temperature range and won't actually move above the middle until the temp is about to go critical.
if the gauge is dropping below the normal temp when driving then the thermostat isn't closing properly and the temp is probably dropping down to about 60-65 degrees at a guess.
another way to tell if the thermostat isn't operating correctly is by how long it takes to warm up. it should come up to normal operating temp within about 5 mins of setting off (will be longer if you let the car sit and idle up to temp). there is also the chance that the car is fitted with a lower temp thermostat.
cool. cheers for that.
Perhaps my best line of attck would be install the temp sensor and be able to get a sense of what my temps are actually doing n then act accordingly.
As noted, the stock gauge is a bit of a joke really...
you could always get a consult cable (or consult display), then you can read the ecu's temp sensor (different one to the dash).
although a new thermostat is probably cheaper than both of them (and not hard to install). you could just buy a new thermostat and put it in. and if it happens to stabilize the temps then you are ahead.
ahhh, this sounds good. I was planning on getting a consult cable and logging software. I didnt realise you could see the coolant temps in digital degrees format though.
back to the issue at hand tho. The readout ill obtain from the consult interface with the OEM temp sensor- how accurate would this be? or is it still a bit ambiguous?
If it is accurate i might just check and monitor it this way and therefore avoid installing the whole aftermarket temp sensor and associated gauges...
cool. Another query i have (excuse the ignorance) is that if i replace the thermostat does that also include the temp sensor in the 1 unit or is it a different component?
Im just htinking i could replcace the thermostat n still be seeing stange temp behaviour if the sensor is also faulty..?
also how much of a job is it to change the thermostat? do u have to drain the whole cooling system? any gaskets or seals need doing?
takes about 20 mins to change the thermostat. you do lose a bit of coolant but not that much. it's just 3 bolts to remove the thermostat housing.
the sensors though don't come with the thermostat and i think they are in different locations. from memory the thermostat is in the lower coolant hose and the temp sensors are in the top hose.
yep its in the lower hose.
Gotta admit thought that all i can see happening when i undo those 3 bolts on the thermostat housing is coolant pissing out of it, and alot of it.
The level of the housing is halfway down my radiatior. So wouldnt half my coolant come pissing out?.
Also how do these thermostats work? Iv got the a replacement OEM one and i can see the spring and mechanism on it but cant move any part of the mechanism by hand (tho im not applying much force as im not sure if trying to move the mechanism by hand is bad for it). How does temperature make the mechanism work? theres no solenoid on it or anything...
cheers
they work off the properties of metal changing with heat (expanding and contracting). no solenoids or anything like that.
the thermostat should be hard to open by hand, but should be possible. very hard to test them though as they will often open when put in boiling water, but you can't be sure whether they are opening too far or not enough. generally i say when in doubt, replace it.
as for losing the water when pulling off the hose, there is a drain plug in the bottom of the radiator. if you have a bucket or 2 handy and just drain some of the coolant out into that. then when you pull out the thermostat you will lose bugger all coolant.
cool. replaced it on the weekend. All seems to be working alot better now (warm up and also maintaining temp when driving.)
cheers again for the info mate. You're a champ.
one final questoin for you. How does this cooling system work vai the thermostat.
by this i mean- after removing the housing it looked like the thermostat appears to completely block the flow of coolant (unless of course it opens.)
is this the case? and if so what is the water pump doing when the thermostat is closed?
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
