Hey all,
Sorry if this has been asked before, I did a search but all I could find were threads asking about wastegate sizes.
I'm seeking a little clarification about plumbing up my wastegate. At the moment, I have it setup so that the top port is venting to atmosphere and the bottom port is getting the feed from my Profec B-Spec II solenoid. But, as I understand it, you can get better boost control by having the EBC apply pressure to the top port to keep the diaphragm shut. So I would like to plumb it up in that configuration. However, neither the Greddy manual nor the Turbosmart manual are very clear about where to get the pressure feeds from.
I believe the bottom port should get it's feed from as close to the compressor as possible, in my case that's a nipple on my hot cooler piping just after the turbo. But at the moment, that nipple is feeding my EBC solenoid. So if I was to move this line to the bottom port on the wastegate, and have the solenoid connected to the top port, where do I get the feed for the solenoid from? Do I tee into the line going to the wastegate? I'm sure it's a simple solution, I just don't want to connect it wrong.
Thanks for any help,
Cheers,
Martin.
https://www.sau.com.au/forums/topic/384394-external-wastegate-plumbing/
ok, to save you the f**king around later, hook kit up the same way as a internal one.. you have an electronic one?
line from MANIFOLD to boost controler -------> to wastgate lower half. top half of wastegate leave open to air.
hooking up the top half of the gate to the controler is another way but is harder to get a stable boost control without spikes etc etc...
ie: do not follow the "external wategate" hose routing that comes with you boost controler..
as far as i know the only reason to plug your EBC into the top of your wastegate is that it will put pressure on the valve which will effectively double your boost pressure..handy if you run out of spring pressure but want more boost....Do you want that??
Perfect, thanks guys :D I thought I was correct with the teeing into the same line theory, wanted to make sure though.
Artz, I believe connecting the EBC to the top port applies pressure to the diaphragm which stops it creeping open, giving better boost control. I'm using two 7psi internal springs which will give me my low boost, but I want to run about 20psi high boost. So either way, this setup appears to be the best option.
  • 1 month later...
Ok Im probably gunna look like a goose here, but I think i have it sorted just like confirmation...:unsure:
Im going to use the boost control in my ECU so, I get a MAC solenoid , seems straight forward but whats 3rd port for
PORT 1..pressure in
2..out to top of gate
3..?????
Also when wiring it up, for it to work with the inbuilt boost control in my Ecu..I assume I can just wire it into the standard solenoid wires, Is that right?
Also does it matter which way the wires go around cause it activates either way when I give it power?...
If I want to install a switch to turn it off and run gate/spring pressue, does this switch just go on either wire?
wrong, it gives better boost control.
make sure you swap the fitting in the solenoid from NO to NC when configuring it this way, otherwise you'll freeboost.
and what does this mean, what is NO or NC fitting.. is it relevant to me at all ??
the 3rd port is left open to atmosphere or returned to the intake before the turbo, this is the air thats bled off to give you extra boost.
your solenoid will have 3 ports, COM, NO and NC. COM should be hooked up to a boost source. NO is used when your running s single port wastegate or actuator, run this to the side of the gate/actuator, or when using a dual power gate leave this open to atmo. NC is only used when you have a dual port gate, hook this up to the top port (with the side seeing a boost source, usually T'd off the COM line), in this case leave NO open to atmo.
yes you can hook it up to the standard wires, shouldnt matter which way they go and yes switch can go on either wire.
:thanks: Johnno
ports only have 1,2,3 on them 1 has a P (pressure) and a filter so obviously is an inlet/COM..
2 is on the opposite side and 3 in the middle..any idea which one is which??
I have dual port gate will hook it up as the diagram i posted...
I noticed that the diagram applies to a stock turbo, is that right? cause i havnt noticed a fitting on the garrett for the hose to fit on.
so if thats right, would you feed off the manifold? and would that pressure be the same as the pressure right near the turbo?
yes..but the pressure will be slightly different depending on how much you have lost through your cooler..
Some turbos do come with a nipple there but I dont believe it matters..
i guess one could be fitted onto the cooler piping after the turbo, :whistling:
might be silly question but i take it you just use one spring inside? could you use a 10psi spring and still be able to adjust upto 20psi?
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
