Any One Got An Exemption For High Powered Vechicle Exemption
  • Replies 51
ive been driving for 4 years and just lost my license on my P1s. does that mean i need to sell my 33 because im not allowed to drive a turbo? i think its a load of shit if thats the case. dont do the 3 year bull crap because its almsot impossible to do it for that long with the demerit points system these days. take the 6 months. trust me because now im doing 15 months.
Sell turbo car, get N/A 4cyl and you may be able to keep your license for longer next time. :thumbsup:
p.s learn to spell before you press the add reply button buddy, your not 10 anymore
you're* :nyaanyaa:
i lost my licence for a fair while, had to go back on L's then p1 right now, i get to still keep n drive my 33 gtr because im over 25 and have held a full licence before...
in this guys case, its 6 of one, 1/2 a dozen of another, when/if he goes to court it could go either way, comes down to the case he puts forward and the judges mood on the day...
you can only try mate, if your unsucessful well at least you tried but then its time to sell up, if you win well you get to pump more hard earned cash into your money pit :(
goodluck
errrr try spelling unsuccessful correctly before you start telling people to learn how to spell :P
The air a little thin up there..?
haha but don't you think it is ironic that you misspelled and used incorrect grammar in a post where you told someone to improve their spelling? I think it is awesome :)
yeah yeah, hilarious :P ... but you get where im coming from, it was getting to a point where every1 couldnt understand what he was writing :/
anyway, keen to see what he does
Yeah I am frustrated daily by the inability of Gen Y to spell or use correct grammar - it is a truly scary thing that one can go through school and not understand the difference between "your" - which is a possessive (will you ride YOUR bike today?), and "you're" - which is a shortening of two words "you are" (YOU'RE going to get run over if you ride your bike on the road).... it is not really that hard.
Take it to court, you'll get an exemption (especially because its your first loss of licence) In saying that, the exemption is just to get you from home to work, not letting you drive your turbo'd car.
Although if you had your licence/car before the laws came in, you'll be able to drive it. Just keep evidence proving this in your car for when you are pulled over.
It's not wise to play the correction game with a school teacher around... ;)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
